Omega Help Area => Omega General Help => Topic started by: bootzey on 16 April 2013, 01:11:29
Title: Volts at MAF plug?
Post by: bootzey on 16 April 2013, 01:11:29
Thought I'd do this in a separate post.
What should the voltages be if connecting the volt meter red wire to the MAF plug and earth the black wire please?
I can't see anyway of testing with the MAF plugged in.
Cheers
Dave
Title: Re: Volts at MAF plug?
Post by: Webby the Bear on 16 April 2013, 12:07:17
i think (and someone will correct me i'm sure) but you can back probe with T pins whilst in use.
i posted up an autodata shot of howe to test it - ill see if i can find it ;;)
Post by: bootzey on 16 April 2013, 12:57:07
Cheers Webby
I saw a post with the readings but I'll be buggered if I can find it again
Cheers  :y
