Omega Help Area => Omega General Help => Topic started by: greenman on 17 April 2013, 20:29:46
eml comes on after running at a steady speed
for a few minutes.
Showing codes p1555&p0170
Any thoughts?
what year/car or are we all psychic? :y
Oops!
,52 2.2.
for a few minutes.
Any thoughts?
http://www.omegaowners.com/forum/index.php?topic=90576.0
P1555 Throttle Position Sensor (TPS) Load Signal not Plausible with Engine Load
P0170 Rich Exhaust
P0170 Lean Exhaust
I would suggest a good clean of the throttle body might help, sounds like it might not be opening/closing correctly.. or the internal airways are gunged up.
Is 0170 the usual lamba sensor issue?
Any advice on the 1555 code?
Did I not just post an answer ?? some 4 minutes ago ??
Try giving throttle body a good clean
http://www.omegaowners.com/forum/index.php?topic=90528.0
and breathers-covered on here before 100s of times before :y :y
Can you read live data. If so, trims please
Can do at weekend
I,ll post then
Just an update
Cleaned breathers& throttle body(really gunged up)
Problem solved
Thanks for help.OOF triumphs again! :y
