Omega Help Area => Omega General Help => Topic started by: chris1973 on 19 April 2013, 23:06:18
Title: wont pull away in drive
Post by: chris1973 on 19 April 2013, 23:06:18
hi am having problems with my omega, i ve just done the head gasket, replace heater valve, coolant temp sensor, thermostat and cam sensor, new timing belt, the problem am having is it wont pull away in d, 1st 2nd 3rd is all fine, eml was on before i started it, drove fine with light on, ive had it checked, its coming up with throttle pedal sensor, i ve also changed throttle body, throttle senor at pedal and air flow meter, still wont pull away in drive, can anyone help me please thanks
Title: Re: wont pull away in drive
Post by: Gaffers on 19 April 2013, 23:42:29
Selector switch cleaned?
Post by: noel on 20 April 2013, 08:32:23
+1
Post by: Michael2.6 on 20 April 2013, 08:55:35
Was the car ok before doing the cam belt head gasket and other works ?
Post by: PhilRich on 20 April 2013, 14:28:33
Is the Multiplug firmly pushed home on the Throttle Body :-\
Post by: chris1973 on 20 April 2013, 16:59:40
hi the car was ok before head got done, eml on but drove ok
Post by: chris1973 on 20 April 2013, 17:01:10
ive put another throttle body on, plug clipped in
Post by: chris1973 on 20 April 2013, 17:02:57
i havent checked that yet, as it was ok before head got done, will check it
