Omega Help Area => Omega General Help => Topic started by: CaptainZok on 22 April 2013, 20:34:01
It must be the time of year for coil pack problems, judging by how many we've seen lately.
So the 246 coil pack is showing a misfire and on exploring has one or two of the rubber boots looking well past their best.
Does anyone have the part no. for the replacement rubber boot kit? I seem to remember it's for the desmond but will work on a 3.2.
4 boots, 4 springs, 9195820
Cheers Rob I knew it wouldn't take you long. :y
That kit is only for the 2.2 engine and will not fit the 3.2 coil packs. For 3.2/2.6 you will need to buy the coil pack itself
Cheers
Andy
Are you sure Andy as I seem to recall they do fit the 2.6/3.2 packs (although not cross referenced on the parts system as doing so).
I know 'man father' used to supply them for such purposes and had them in his 'black book' of useful to know part numbers.
They may do but can only go by EPC unless someone else can confirm 100%. Don't want to sell some one a boot set only to find it doesn't fit
Cheers
Andy
Oh they do fit, correct length etc, repaired a few like this :y
If its only the rubber boot I should have two used ones from the 2.6 if that would help?
I know no 2 is fubar, but the other two may be ok?
I had planned on keeping them as spares, but if you need them ...... :y
This is a 2.2 coil pack boot.showing size HTH :y
(https://dl.dropboxusercontent.com/u/70807181/coil%20rubber.JPG)
Thanks for the offer Jonny but I've just remembered that £40 masterfit voucher so it looks like I'll be getting some new ones from VX.
No worries pal :y
Andy,
How much is the set of 4 for the 2.2 please?
Steve
