		Omega Help Area => Omega General Help => Topic started by: YZ250 on 23 April 2013, 17:47:48
				Not really an electrical problem so I've put it here.  :y
 Should be so simple but I could rebuild an engine quicker than I can get the accessory socket out.   ::) ;D
 I thought my phone charger had died but it appears to be the socket in the rear of the centre console that is at fault.  :-\  I have checked the fuse and the time delay and they are fine so I removed the arm rest, complete with the power socket and heated seat buttons, tested the wiring and that's OK so I assume it's the power socket itself.
 I have squeezed the tabs, levered the tabs and they are rigid so I conclude that there must be some sort of twisting / squeezing solution to removing it.  ::)
 It's a sad day when I'm defeated by a bit of plastic, so come on guys, what's the method please.   :-\
				Rear acc. socket has it`s own relay energised by the timer delay relay.
 Bank of three up above the fuse box on the drivers side and coloured Red, Yellow & Green.
 Green is the acc. relay. Have you checked that before swapping out the socket
 Cheers for the reply Rob.  :y
 No, I haven't checked that as I have power getting to the socket so I assumed it was the socket, but thanks for that, I'll check that in the morning.  :y
 Relay`s good then
				When I removed one from a breaker I had to destroy the casing to get it out
 :o :o
 I thought it was just me struggling with it.  ;D
 Might just relocate another one then.  :y
 Cheers.  :y
				Sorted now.  :y
 Used circlip pliers with angled prongs pointing outwards, locate in metal cylinder slot tabs, squeeze pliers and pull metal cylinder up.
 So easy when you know how.   ::) :y
