		Omega Help Area => Omega General Help => Topic started by: Mr frost on 28 April 2013, 15:26:41
				Hi everyone ,
Just wondered if anybody had all the part numbers for all of the gaskets that fit on both of the inlet manifolds on a 2.6 omega .  I'm looking to replace all mine and our local dealer isn't great as its only just got the vauxhall franchise.  ???
Many thanks
				I wouldnt bother replacing them unless there is an obvious problem with them.You can remove plenum/manifold etc. numerous times without needing to replace them.If you really do need them send a PM to AndyC on here and he will sort you out a good price with fast delivery. :y
				a very light smear of fresh oil on the rubber gaskets helps make an airtight seal and keep the seal fresh.
