Chat Area => General Car Chat => Topic started by: pauls on 30 April 2013, 21:24:05
Title: wind
Post by: pauls on 30 April 2013, 21:24:05
Hi anybody got a idea of how i can stop the wind coming in thru my passenger doors. i have adjusted both doors but it did not help.
Title: Re: wind
Post by: Webby the Bear on 30 April 2013, 21:25:03
Shut them?  :-\
 :D :D :D :D :D Sorry mate couldn't resist
I'll shut up now  :-[ :-[ :-[ ::) :D
Title: Re: wind
Post by: Gaffers on 30 April 2013, 21:29:04
stop giving lifts to the fat shadow? ::)
Title: Re: wind
Post by: Sir Tigger KC on 30 April 2013, 22:50:25
Try giving your passenger charcoal tablets!  ;)
Title: Re: wind
Post by: dbdb on 01 May 2013, 01:06:34
It's going to be hard to be serious on this thread but try and find out where it is coming in, use strips of paper to see where the gaps are.  If you can't adjust the door you can apply sealant to one surface and wrap the other with cling film and then close door until it sets. Or even cling film on the door and expanding spray foam on the frame but it spreads like mad and won't look pretty.
Title: Re: wind
Post by: pauls on 01 May 2013, 12:16:01
Thanks for the advice chaps ;D ;D ;D. I have seen somewhere that you can get some very thin hard rubber that you can run inside the orginal door rubbers but I cant think where you can get it from.
Title: Re: wind
Post by: the alarming man on 01 May 2013, 20:33:44
i get a draught through the gaps around inside door unlock handle... :y
Title: Re: wind
Post by: plym ian on 02 May 2013, 07:41:44
Get a smoke machine, saw it on wheeler dealers once. You put smoke machine in car close it up and where ever smoke comes drone hey presto you have your source
Title: Re: wind
Post by: mantahatch on 02 May 2013, 07:48:45
We use smoke machines at work, just be careful they get hot and if over used can leave a film of oily residue on all surfaces.
Title: Re: wind
Post by: symes on 02 May 2013, 18:00:54
problem is wind gets in through check stap hole in door and exits at inner door release handle-large piece of foam over hole might help-maybe? I got same problem and will do that saturday-if I get time :y
