Chat Area => General Car Chat => Topic started by: Steve Brookman on 04 May 2013, 11:16:19
Title: Ford Sierra Radiator
Post by: Steve Brookman on 04 May 2013, 11:16:19
Morning all,
Still having slight issues with my Sierra. Started getting hot a bout 8 months ago-replaced water pump, thermostat and foolishly (I think) the HG. On the level the car is fine but when you come to a hill the temp starts to rise-it doesn't overheat but climbs rapidly towrds the Red.
I'm now suspecting a partially blocked radiator-I tried flushing a few months back and it did make a slight difference. The radiator is original and 20 years old.
Any ideas greatly appreciated./
Steve
Title: Re: Ford Sierra Radiator
Post by: ozzycat on 04 May 2013, 11:37:20
could be the radiator try the holts 2 part flush its worked for me but somr peeps on here may have a better solution
Post by: symes on 04 May 2013, 11:42:12
take radiator out and stick hose in it and flush it through while rad is placed side ways/upside down -works on rover p6 rads :y
you can blank other outlet on rad with plastic bag/hose clip if required
Post by: Steve Brookman on 04 May 2013, 11:51:26
Thanks,
Tried the 2 part flush-will take it out.
The radiator on my P6 was very easy to take out if I remember!
Wish I still had it (P6 3500S).
Thanks
Steve
Post by: symes on 04 May 2013, 11:54:48
Thanks,
Thanks
Steve
mine is 1965 2000 with buick 300 in its nose ;)-am doing fron lower ball joint later today :'( right pain to do >:(
Post by: sassanach on 04 May 2013, 12:06:48
just stick your mitt on the rad when the engine is hot,it should be warm at the bottom and stinking hot at the top.you will NEVER successfully flush a parallel flow rad that has furred up inside.water gives up its limescale at approx 60c, engines run at approx 95c.
Post by: biggriffin on 04 May 2013, 13:17:33
Go to plumcentre/screwfix and get some fernox flush. Top stuff. :y
Post by: martin42 on 04 May 2013, 14:57:40
to be fair using a fernox etc could make matters worse,personally if it is orginal,get it refurbed or replacement,will be quickest and easiest option  :y
Post by: Steve Brookman on 04 May 2013, 17:07:47
Thanks all,
Will get a new one.
Cheers
Steve
Post by: 0795omega on 04 May 2013, 17:11:18
are you sure it is actually getting hot,i had a 1990 2.0 pinto sapphire thats guage would sore into red,it was a faulty guage in the end nothing wrong with engine!
Post by: Taxi_Driver on 04 May 2013, 17:11:26
Some of that stuff eats aluminium as well as limescale  ;)
Post by: Taxi_Driver on 04 May 2013, 17:14:08
Very true......tho you could use distilled water i guess..... :-\
Post by: sassanach on 04 May 2013, 18:49:02
i do  :y
Post by: Sir Tigger KC on 05 May 2013, 22:29:18
I used that on a 20 year old combi-boiler once thinking it would improve the performance.  Not long after the heat exchanger failed and I had to buy a new boiler....  ::)  :'(
Post by: 05omegav6 on 06 May 2013, 01:49:29
i do  :y
+1 :y
