Omega Help Area => Omega General Help => Topic started by: animal65 on 08 May 2013, 08:46:42
Title: New MOT Rules regarding HIDs as confirmed by VOSA
Post by: animal65 on 08 May 2013, 08:46:42
As you are probably all aware from my post regarding headlamp washer jets and the fact you cant seem to buy these anywhere. Well I have some good news if your vehicles come factory fitted with self leveling headlamps and has broken or missing washer jets VOSA have confirmed if you remove the headlamp washer system the mot stations are unable to check these and therefore can not be failed. So my advice to you all i you have issues with the washer jets on your headlights remove them before MOT. I thought i would share this with you all.
Title: Re: New MOT Rules regarding HIDs as confirmed by VOSA
Post by: Jimbob on 08 May 2013, 08:48:52
I wonder if pipes with missing parts will still mean a fail though?
Post by: animal65 on 08 May 2013, 08:54:50
They are not allowed to remove parts of your car to check things ad in order to check pipes depending where the jets are located they would have to remove bumper or grille  so my advice to you is pop a gromit in the holes. All VOSA said is if the jets are not there altogether they cant be checked
Post by: animal65 on 08 May 2013, 08:56:09
If pipes are disconnected and no water pumping out and the jets have been removed its not a fail
Post by: TheBoy on 08 May 2013, 18:11:47
Whats wrong with fixing the faulty parts  :-\
I've never had trouble getting the parts for PFL, and I'm sure FL are even more common.
Post by: animal65 on 08 May 2013, 18:23:54
Cant get headlight washer jets they are rare as rocking horse poo
Post by: Jimbob on 08 May 2013, 18:25:13
I may have one....not sure, and not sure which side...
Post by: animal65 on 08 May 2013, 18:27:07
we have mini facelift omega and the missing jet is n/s
Post by: Jimbob on 08 May 2013, 18:28:01
Ill see if I can have a check when I get home.
Post by: RobG on 08 May 2013, 18:37:48
Any particular reason why F/L washers can`t be mounted on a PFL :-\ :-\
Post by: TheBoy on 08 May 2013, 18:39:14
Bumper isn't as gay as the "Rover 800 facelift" style bulbous FL bumpers. Hence the extendable squirters
Post by: dazzerM on 08 May 2013, 18:42:07
I take it they don't check if they actually serve a purpose
nitro (Ken) has had his headlamp washer jets mounted the wrong way round for atleast the last few years I have known him  ;D ;D ;D
Post by: Andy B on 08 May 2013, 18:42:32
I see that The Boy is back to 'normal'  ::) ::)
Post by: TheBoy on 08 May 2013, 18:44:06
What have I done now?
Post by: Andy B on 08 May 2013, 18:51:09
Nothing  ;) Just saying that your posts are up to their usual 'gay' standard! You're obviously feeling much better ....  :y :y
Post by: steve6367 on 08 May 2013, 18:57:02
I has to be better to fix the fault - the systems are fitted to HID headlights to prevent other road users being dazzled, which has to be  a good thing.
Post by: sassanach on 08 May 2013, 21:32:54
the washer jets do the square root of f/a,they are there i reckon as the token effort to comply with b+llshit legislation
Post by: RobG on 08 May 2013, 21:43:37
That much ;D ;D
Post by: tunnie on 08 May 2013, 21:47:01
Have to disagree, on the 3.2 if driven for a while. I can see a noticable improvement at night when washed, makes a big difference IMHO  :y
Post by: ffcgary1 on 09 May 2013, 17:40:48
 I have to agree with sassanach with regards to washer system. if you jet was a dirty car and then let it dry the car will still be dirty, you need to activly disturb the grime to remove it and generaly on the headlights it will be a wiper then spray with screen wash.
Gary
Post by: Big_Al on 09 May 2013, 18:31:26
Gary
Me as well Gary & Sass , always thought the Omega headlamp washer  system to be a bit of a novelty rather than effective  ::) ::)
Post by: TheBoy on 09 May 2013, 18:42:14
I find they make a difference, as much of that November time grim doesn't get engrain before you wash it.
Trouble is, it soon empties the bottle (for those who leave them fully functional before Andy B pipes up ;D)
Post by: ffcgary1 on 09 May 2013, 18:46:10
it does use a lot of fluid i have to agree, screen wash manufacturers must love omega owners. ::)
Post by: TheBoy on 09 May 2013, 18:49:31
They love the ol' bag. I reckon her wash relay is wired into the ignition.
Post by: ffcgary1 on 09 May 2013, 21:34:24
wired to the water main. ;D
Post by: Andy B on 09 May 2013, 23:10:44
That reminds me .... must dig out a fuse before Omega's next MOT  ::)
