Omega Help Area => Omega General Help => Topic started by: jonny2112 on 09 May 2013, 18:43:58
As a matter of intetest, when you remove the ashtray is there a void behind it, or is it 'blocked off'?
Either way, is there an opportunity to run small cables through towards the back of the dash?
With a bit of drilling.
Ashtray is 1 screw, so look ;)
I know, just being lazy ::)
My car's at home so can't check right now, and the light bulb has only just come on in my head about running the cables :D
Depends on the cables :-\ once you've got the ashtray out, you'll need to remove the radio mounting frame (the bit the cage sits in), and the wood trim. Then you'll be able to see what's what. Not that much room to run much of anything behind there :-\
Ah thanks for that was wondering why it wasn't coming out while I was tugging it :D ;D
Will have a gander tomorrow ..
d'ya mind me asking whats the cables actually for ...?
Not at all :)
I run a power cable and an audio cable to my phone holder but its not that tidy.
Just thought it was an idea, but sounds like hassle! I'll just route them a bit better :y
