Omega Help Area => Omega General Help => Topic started by: Webby the Bear on 13 May 2013, 17:14:01
Hi guys, as above, when I put the indicators on (right or left) they stay solid and don't flash.
obviously the bulbs are good as I've checked and all bulbs are on.
can someone post up a fusebox layout as i'm presuming I need to check the fuses for the indicators. I also assume there's a ''flasher'' system and I presume theres a relay/fuse for that too. if you can tell me where this is?
then if all that's good am I looking at a new flasher unit?
what happens when you put the hazzards on?
excellent point. 2 ses.....
yep, still the same.... on but no flashing.........
Try turning hazard switch on and off about 20 times ;)
If that doesn't work I'd suspect flasher unit
already done that mate :'( :y
Didn't you have the same problem a while back Webs? What did you do then to fix?
The flasher relay is in the fuse/relay box under the steering column. :y
Next to diag socket IIRC
spot on guys.... which is the number to check.....
http://oldsite.omegaowners.com/forum/YaBB.pl?num=1161602010/0
dbug, youre spot on it did happen a while back. but sorted itself out when I was mashing the hazrds a few times. how strange!
if the fuse is good wheres the flasher unit located?
cheers guys
cheers guys
The flasher relay is in the fuse/relay box under the steering column. ...... ::) ::)
cheers guys
I assumed there was a relay AND a flasher unit (like an actuator), soz ::) :y
in the link I posted is it no. 2 fuse/relay?
cheers guys
Not sure without going & looking ;) (I'm comfy ::)). I normally feel for the one that's clicking when the indicators/hazards are on ::) ::)
cheers guys
lol no worries ill go and see what I can do now cheers andy :y
Thanks guys all sorted.
Checked the relay and it wasn't clicking ::) :y
Swapped it out for the one taken off Ralf..... all sorted :y :y :y :y :y
cheers dudes
xxx
cheers dudes
xxx
Easy, cheap fixes are always the best. :y :y
Glad you're sorted Webs :y
cheers lads :y :y :y
cheers dudes
xxx
Ralf saves the day again ::) ;D
