Chat Area => General Discussion Area => Topic started by: Andy B on 22 May 2013, 17:18:01
Title: computer fans wiring
Post by: Andy B on 22 May 2013, 17:18:01
I've a couple of computer fans with red, black & white wires going to the pcb. Red & black are obviously 12v & 0v (Yes, I know Mark  ;) )
Out of interest, what's the white one likely to be for?  :-\
Title: Re: computer fans wiring
Post by: RobG on 22 May 2013, 17:23:17
Motherboard, (monitors fan speed)
Post by: Andy B on 22 May 2013, 18:17:04
Thank you Rob  :y  :y  :y
Post by: RobG on 22 May 2013, 18:19:05
Was there a specific reason for asking or just curiosity
Post by: Andy B on 22 May 2013, 18:21:21
Just curious  :y
I have a couple of fans that I want to rig up at the top vent of my caravan's fridge for use in (hopefully hot) French France. I was testing the fans & just wondered what the white wire was for .........  ;) ;)
Post by: RobG on 22 May 2013, 18:40:15
Just curious  :y
White not needed then :)
Post by: Andy B on 22 May 2013, 18:45:15
Indeed!  :y  :y
Post by: CaptainZok on 22 May 2013, 18:54:32
Unless you want to bore impress Annette with the speed your fans are running at. ;D ;D
Post by: Andy B on 22 May 2013, 18:57:27
No ..... as long as they run when they're supposed to  ;)  ;)
Post by: Gaffers on 22 May 2013, 20:08:19
It wouldn't be difficult to use the signal to feed a monitoring device so that you can be informed when/if one stops working  :y
Post by: Andy B on 22 May 2013, 20:49:19
I think it would in my case ..........  ;D  ;D  ;D
Post by: Marks DTM Calib on 23 May 2013, 09:15:20
Easier than you think as its only a tacho output.
Post by: slowboy on 24 May 2013, 14:37:11
Note.for france never park with fridge vent facing the sun :y
Post by: Entwood on 24 May 2013, 14:44:44
Makes no difference to me .. fridge vent is inside the awning ! ... What does happen is that if you go out for the day and close up the awning, it gets very hot in there and the "thermal circuit" around the fridge is insufficient to cool the fridge down.
Two solutions ... Andy's of a computor fan just inside the vent area to move the air...
or mine ...
A small 12v car fan, the type designed to suction to the windscreen, but mine is mounted on a small piece of ply with two "lugs" protruding .....  These "lugs" slot into the fridge vent and hold the fan close to, but not touching, the lower vent. Plug that into a 12volt supply and it forces air into the cooling fins of the fridge... result ... nice cold beer on your return .. :)
Advantage is no modification to the 'van wiring at all, and it moves with me every time I change the van .. :)
Post by: Andy B on 24 May 2013, 15:58:46
or mine ...
Sounds like a nice simple idea  :y
We use (as IIRC you do) a seperate 12v/240v beer fridge  :y  :y
