Omega Help Area => Omega General Help => Topic started by: terry paget on 01 June 2013, 14:28:11
Title: Should I oil or grease my discs?
Post by: terry paget on 01 June 2013, 14:28:11
Having replaced my shiny new solid rear discs with the older worn ventilated rear discs, I am wondering how best to store the new solid discs until I fit them to one of my 2 litre Omegas. I fear they will rust if I just put them on a shelf in the garage. Should I oil them, grease them, or just seal them in a poly bag dry?
Title: Re: Should I oil or grease my discs?
Post by: 05omegav6 on 01 June 2013, 14:31:00
A coat of light oil might be prudent if storing them for a while :-\ Be sure to thoroughly degrease them prior to fitting them though :y
Post by: YZ250 on 01 June 2013, 17:11:40
I would avoid a polythene bag as it may sweat and cause them to rust.  :y
As Al said, a light smear of grease/oil may be beneficial, as after all, they are delivered greased.
Must admit thinking it was a joke when I read the topic title.  ;D ;D :y
Post by: martin42 on 01 June 2013, 17:45:36
if youve gone from ventilated to solid rear dics which are thinner,il be looking forward to ive crashed my car as brakes failed due to brake piston popping out of rear caliper  :o :o
Post by: Andy B on 01 June 2013, 18:54:21
See towards the end of this thread  ;)   ;)
http://www.omegaowners.com/forum/index.php?topic=115034.0
Post by: Shackeng on 01 June 2013, 20:05:19
T'other way round :y
Post by: biggriffin on 01 June 2013, 21:54:00
For storeing discs,
1 cardboard box
2 gresaproof paper
3 tin hmp grase
4 paint brush.
Apply grease all over disc's using paint brush,dont be shy,then wrap in grease proof,place in box and store some were dry.
 when you come to degreasing them to use,get some brake cleaner to remove the grease. :y
Post by: flexbuttcheck1 on 01 June 2013, 21:58:33
wd40 i find the best for storing discs as when your ready to use them just a quick wipe off will surfice as any left over wd will just burn off when used
Post by: biggriffin on 01 June 2013, 22:14:13
Think op wants long term storage,as rear discs last for years. :)
Post by: dbug on 01 June 2013, 22:16:00
Yep grease em and store as biggrifin says - thats the way they are supplied new.  WD40 not the right product for this application ;)
Post by: symes on 01 June 2013, 22:26:43
water in that stuff
Post by: dbug on 01 June 2013, 22:27:52
water in that stuff
Don't think so its actually a silicone based water repellent ;D ;D ;)
Post by: flexbuttcheck1 on 01 June 2013, 23:42:18
never had any problems with wd40 ive got discs in my shed from my viva that ive had for at least 15 years and every now and then ill just give them a quick top up spray and there still in tip top condition
Post by: slowboy on 03 June 2013, 20:38:39
Are discs in short supply? I don't oil or grease my gold ingots
Post by: dbug on 03 June 2013, 22:05:38
WD40 is ok for gold ingots  ;D ;D ;)
Post by: dbdb on 04 June 2013, 23:37:18
water in that stuff
That's very unlikely as there is no silicone in WD40 ???
Post by: Webby the Bear on 05 June 2013, 09:11:15
WD40 for storage. Brake/Carb cleaner before they go on the car. Simplez.
