Omega Help Area => Omega Electrical and Audio Help => Topic started by: Jan Suhr on 03 June 2013, 10:11:54
Title: Alternator, which one?
Post by: Jan Suhr on 03 June 2013, 10:11:54
It seems that my alternator on my 3.2 V6 2001 has broke down.
On the scrap yards here in Sweden I have found two for the 3.0 V6, will they fit on my car?
I have looked at eBay in UK but could only find 3.0s there too...
Kind of urgent  :'(
Thanks
Jan
Title: Re: Alternator, which one?
Post by: Marks DTM Calib on 03 June 2013, 10:43:24
One from a 3.0 will fit.
Post by: Jan Suhr on 03 June 2013, 10:47:01
Thanks
Even if they are from a 1999 or 2000 year car?
Jan
Post by: Marks DTM Calib on 03 June 2013, 13:22:05
Yes, slightly reduced charging current (read 10-20A) but direct bolt on replacement
Post by: tigers_gonads on 03 June 2013, 13:24:54
Wouldn't it be easier / cheaper to change the regulator providing the bearings are ok ?
Post by: Jan Suhr on 03 June 2013, 13:35:15
Well, maybe so.
I found one in the scrapyard that had been refurnished with new bearings and parts.
I might repair the old one and keep as a spare.
Thanks
Jan
Post by: Jan Suhr on 03 June 2013, 18:14:14
The problem I had occurred this morning. I was driving to Stockholm 110 km from home. When I got there it was heavy traffic I spent a lot of time standing still in idle. Then some lights went on in the dash. Airbag, ABS and TractionControl went on but with a fade. I went out in the next lane were the traffic flowed ( I was on an exit ramp) and the lights went out. But when they did the battery light went on for a short while. Then I ended up in another traffic jam and after a while of standing still on idle the three lights came back on again. I was able to turn around and when I got up to speed the lights went out. Temp guage showed 100°C.
I decided to park the car, opened the hood to let it cool down. After 30 minutes I tried to start it and it was almost dead and wouldn't crank. I left it and went to my visit I was going to.
Then in the afternoon I got back, it started without any problem, cranked as always. I drove all the way home without any glitches.
I took a voltage reading on the battery and it showed 12.3V. Kind of low I think.
I guess this was temperature related, outside temp were 23°C. It should handle that, it's not extreme. Both fans are running, coolant is OK. It might need a flushing.
Hope it gets better when I change the alternator.
Jan
Post by: Doctor Gollum on 04 June 2013, 21:08:37
Erm.  3.0 wouldn't fit when vx ran out of 3.2 ones and tried to sell me a 3.0 one. Loom wouldn't reach the new post positions, and the loom spade connector was too big.  :-\
Post by: Doctor Gollum on 04 June 2013, 21:09:30
Although master may have made his fit somehow.  :-\
Post by: Marks DTM Calib on 05 June 2013, 14:28:07
Fitted a few now, cant recall changing anything.
Unless there was a later change to the loom on 2003 models.
Post by: Doctor Gollum on 06 June 2013, 00:33:28
This is what I had.
3.2 at the top of the pic. Cable spade connector wouldn't reach or fit on the bottom post ime.  :-\
Might be a loom difference I suppose.  :-\
(http://i344.photobucket.com/albums/p326/chrisgixer/9B3472A0-D1E2-40E0-A60C-A5C4FB719ECF-610-000000FC985EDE7A.jpg)
Post by: Jan Suhr on 11 June 2013, 09:02:16
Same thing for me, the 3.0 alternator had the connectors in different positions. But I was able to bend and twist the feed cable around to get it to fit. I did the connections before I mounted the new one.
Jan
