Chat Area => General Discussion Area => Topic started by: redelitev6 on 05 June 2013, 18:15:39
Title: Laptop hard drive
Post by: redelitev6 on 05 June 2013, 18:15:39
Are they plug and play or do you need to format anything? the daughters lappy has got a "hard disc error" message on screen, I've made the fatal mistake of taking it to the muppets in PC world where they gave me the usual spiel about send it off- £50 now and diagnose fault, cost of this and that ,  I can imagine it mounting up nicely. Is it a hard job changing a drive?
Title: Re: Laptop hard drive
Post by: dbug on 05 June 2013, 18:18:47
Not plug and play, need formatting.  You have that option in the Windows install - assuming you'll be installing Windoz ;)
Post by: TheBoy on 05 June 2013, 21:48:30
As its a laptop, its likely its the system drive as dbug implies. That means it needs Windows reinstall.
The fact you are asking this Q answers one of dbug's implications, as its fair to say that "alternatives to Windows" are probably unsuitable.
Post by: Plomien on 05 June 2013, 22:02:49
You can buy a replacement HDD for the laptop for the £50, depending on what has caused the failure its unplug and put new one in, then install windows.
If you were down my neck of the woods I would happily sort it for you, if you know someone who has a bit of PC knowledge then its and easy repair :)
Post by: Vamps on 05 June 2013, 22:08:36
I had what I thought was HD failure, even the IT guy from work could not fix it, ended up with a new lap top...... ::) ::)
