Omega Help Area => Omega General Help => Topic started by: tOnYoYo on 05 June 2013, 20:15:21
Title: Ran fine but now won't start
Post by: tOnYoYo on 05 June 2013, 20:15:21
Hi people!
Just did a few short errands in my 2002 3.2 Elite, parked up to get stuff out the boot and now she won't start!  :'(
Seems to be turning over ok, but won't even try to actually fire up. Any ideas?
Thanks guys!
Title: Re: Ran fine but now won't start
Post by: zirk on 05 June 2013, 20:20:42
Any Fault Codes? from a Peddle Trick.
Edit: take it you havn't parked up on a slope with the Fuel Light on?
Post by: Andy B on 05 June 2013, 20:22:06
crank sensor  :-\
Post by: Rods2 on 05 June 2013, 20:26:39
Is the engine management light on?
If so you can read the fault codes using this guide:
http://www.omegaowners.com/forum/index.php?topic=90581.0 (http://www.omegaowners.com/forum/index.php?topic=90581.0)
Is there plenty of fuel in the tank? Low fuel and parking on a slope can cause this.
Another possible cause is a faulty crank sensor as this is a common problem.
Post by: tOnYoYo on 05 June 2013, 20:38:59
wOW you guys are fast...  :D
The pedal trick worked for me (can you believe I don't own a paperclip?).
0335 - Crank position sensor...
Is that... Bad..?  :(
Post by: RobG on 05 June 2013, 20:41:30
Yep. Replace with genuine only
Post by: albitz on 05 June 2013, 20:41:50
Approx £70 bad,for the part,buy genuine part only.And about 10 minutes  to fit once you've read the relevant guide on here. :y
Tip-dont waste time trying to remove the old one from the car.Just leave it hanging in limbo.The wiring from the new one will use a different route anyway,as you will find out in the guide. :y
Post by: tOnYoYo on 05 June 2013, 20:44:05
That is not helping with my house purchase...  :-\
Can I just rub the old one or something? Hit it with a spanner? Buy it dinner? ;D
Post by: albitz on 05 June 2013, 20:47:38
Nope.Due to the wiring being routed so close to the exhaust manifold,it breaks down inside eventually.It may decide to work again temporarily and then stop again once the engine has warmed up. This is why the replacement needs to have the wiring routed differently,as the problem would rear its head again in time. :y
Post by: Andy B on 05 June 2013, 20:49:06
Just think of the price of a crank sensor as being something similar to what a garage would've charged you for diagnosing what you've just found out for free via the peddle trick  :y :y :y
Post by: albitz on 05 June 2013, 20:59:09
Tut tut Andy. ::) ;D
Post by: Andy B on 05 June 2013, 21:02:44
no idea where that came from ...........  ??? ???
(off to find my hair shirt & flagellation whip!  ;))
Post by: albitz on 05 June 2013, 21:07:49
I should think so too. ;D
Post by: CaptainZok on 05 June 2013, 21:08:50
(off to find my hair shirt & flagellation whip!  ;) )
That's what you get for working in the land of the rising pie. ;D ;D
Post by: Andy B on 05 June 2013, 21:19:33
 ;D ;D ;D ;D ;D
Post by: tOnYoYo on 05 June 2013, 21:25:40
True!  ;D
Where can I purchase on of these CPSs? Any trusted UK sites that might have it with me by Saturday?
Post by: 05omegav6 on 05 June 2013, 21:28:42
Try Now Vauxhall in Byfleet :y they seem to stock all sorts of random Omega parts :y
Failing that, AndyC is the person to ask on here :y
Post by: Andy B on 05 June 2013, 22:08:06
Andy Clears aka andyc has his details here. Parts manager at Bury St Edmonds Vauxhall
http://www.omegaowners.com/forum/index.php?action=profile;u=1488
Post by: 05omegav6 on 05 June 2013, 23:30:28
Andy Clears aka andyc has his details here. Parts manager at Bury St EdmUnds Vauxhall
Fixed that for you :P
Post by: tOnYoYo on 12 June 2013, 20:09:24
10 minute job they said...
It'll be easy they said...
 :o
How do you /remove/ the sensor? Is it held in place by Thor himself?!  ???
Advice appreciated! It's raining and the job's half done...  :'(
Post by: tunnie on 12 June 2013, 20:17:00
Small torx bolt removed at the sensor itself, near the oil filter. It should just pop out, small flat head screwdriver might be needed to wiggle it out.
Pop the scuttle off, for easy access to route/plug it in  :)
Post by: tunnie on 12 June 2013, 20:17:46
Guide: http://www.omegaowners.com/forum/index.php?topic=90540.0 (http://www.omegaowners.com/forum/index.php?topic=90540.0)
Post by: tOnYoYo on 12 June 2013, 20:18:18
It's the wiggling out I'm struggling with...  ::)
Post by: tOnYoYo on 12 June 2013, 20:30:45
I got it! I got it!  ;D  :D  8)
Post by: hotel21 on 12 June 2013, 20:59:33
......but does it now start and run?   :y
Post by: tOnYoYo on 12 June 2013, 21:24:36
Starts, runs, stops and restarts.
I think we have a fixed Omega  ;)
Post by: Doctor Gollum on 12 June 2013, 21:25:29
Result :y
Bet you're glad to be back inside :y
Post by: tOnYoYo on 12 June 2013, 21:33:49
Love that sweet V6 hum...  :D
Thank you guys!
Post by: tunnie on 12 June 2013, 21:37:23
Good stuff  :y
Post by: Doctor Gollum on 12 June 2013, 21:39:12
Thank you guys!
If it hums, try one of theses... http://www.ebay.co.uk/itm/MAGIC-TREE-CAR-AIR-FRESHENER-ICE-CREAM-ORIGINAL-BEST-WUNDER-BAUM-NEW-/170781013034  (http://www.ebay.co.uk/itm/MAGIC-TREE-CAR-AIR-FRESHENER-ICE-CREAM-ORIGINAL-BEST-WUNDER-BAUM-NEW-/170781013034)
Post by: Andy B on 12 June 2013, 22:31:35
I was close enough ........ there's only ONE Bury!  ;)  ;)  ;) (didn't see this till now  ;))
Post by: Andy B on 12 June 2013, 22:32:49
 :-X :-X :-X :-X :-X :-X  ::)
Post by: Doctor Gollum on 12 June 2013, 23:58:11
What ::)
Post by: tOnYoYo on 13 June 2013, 00:01:19
 :D  ;D
Post by: Andy B on 13 June 2013, 00:03:11
What ::)
nothing .........  ::) ::) ::)  ;)
Post by: Doctor Gollum on 13 June 2013, 00:04:19
Ok :y
Post by: Andy B on 13 June 2013, 00:05:08
Ok :y
 :y :y :y
Post by: Steve B on 13 June 2013, 00:11:38
Thank you guys!
2.2 sounds better  :y
