Omega Help Area => Omega General Help => Topic started by: Nick27 on 20 June 2013, 21:23:50
Title: Air con not working
Post by: Nick27 on 20 June 2013, 21:23:50
Hi,
A/C is not working on my car, even though recent refilled the gas. I spoke to the garage who refilled the gas on the phone he said that there might be a leakage on the air con radiator. is it the case really? Every summer I have to get it refilled and last time I did asked the garage to check whether there is a leakage and they confirmed no leakage.  :-\
Can you guys please help.
Thanks,
Nick.
Title: Re: Air con not working
Post by: jonny2112 on 20 June 2013, 22:05:16
Was a pressure test done?
This was the problem with mine.
Post by: Nick27 on 20 June 2013, 22:10:25
Not now but last he did that but I cant remember what the readings were
Post by: jonny2112 on 20 June 2013, 22:15:45
When mine wasn't working I thought it simply needed charged. It still didn't work and I complained. Apparently the pressure test is not part of the process, but the leak rest may be.
In the end a little valve needed replaced once I had requested the test be done and the problem then confirmed.
Just a thought  :y
Post by: Nick27 on 20 June 2013, 22:21:18
Just a thought  :y
Hmmm....i should then ask to have a leak test around the valves. :y
Post by: biggriffin on 20 June 2013, 22:44:24
A/c needs to be pressure tested with nitrogen to find if there is a leak,then tested with dye to find the leak.
Condensors seem to leak at the bottom corners,or near the battery tray,the L/P valve is just a normal.tyre valve core, the H/P valve(port) is 13277003 £4.19 on tc.
Post by: TheBoy on 21 June 2013, 08:17:49
If its a slow leak - ie takes weeks before it stops working - pressure/leak tests won't show it. They should put dye in it, and that will reveal the leak when its leaked most of the refrigerent out weeks later.
Post by: Nick27 on 22 June 2013, 17:16:35
okkkkaay!! went to a garage this morning they performed a test and showed that the compressor has gone. checked the price on eurocarparts  its around £230 + labour of £80. spending around £300 :'(
does anybody here breaking the car and have it available?
Thanks.
Nick.
Post by: Big_Al on 22 June 2013, 17:28:28
Post a "wanted" ad in the Test zone  . . as you don't have enough posts for the wanted section  :(
Admin will usually move it to "wanted"  for you  ;) ;)
Post by: Nick27 on 22 June 2013, 17:43:39
cheers mate! :y
Post by: albitz on 22 June 2013, 17:52:09
I have two of them,but neither of them have been used on a car for at least 6 months. I have heard it said that the seals can dry out if they aren't used,so it might be a bit of a gamble tbh. Might be worth asking for opinions before diving in ,but I only want £20 for one,and your close enough to not have to pay the postage,which would be expensive for something so heavy.
Post by: Nick27 on 22 June 2013, 18:02:32
Thanks Mate. Can anyone please advise on the highlighted?
Albitz whereabout are you? I live close enough to Romford.
Thanks,
Post by: albitz on 22 June 2013, 18:11:50
When Im at work Im just off the A12 near Hatfield peveral,so about half an hour away from Romford. ;)
Post by: RobG on 22 June 2013, 18:24:40
cough, cough ;D
Post by: Nick27 on 22 June 2013, 18:39:18
RobG can you please advise on this?
Post by: RobG on 22 June 2013, 19:02:59
"Gone" meaning what actually?
Yep, seals can dry out if A/C not used regularly.
Post by: Nick27 on 22 June 2013, 20:13:02
Selonoids not working in the compressor.
I also noticed that when i switch on A/c rpm normally goes down a bit but not anymore.
Post by: RobG on 22 June 2013, 20:25:33
What test did they perform, 12V direct to compressor?
Post by: Nick27 on 22 June 2013, 20:32:17
Not sure but they had the machine attached to the valves where the gas is refilled from, he told me that he injected an oil to perform test. Sorry not a very technical person  :-\
Post by: RobG on 22 June 2013, 20:34:58
Doesn`t sound very knowledgeable ???
To confirm if the compressor is knackered you need to unplug connector and apply 12V & 0V to contacts and see if the clutch engages
Post by: RobG on 22 June 2013, 20:44:41
Has been known, but seals usually dry out due to the effect of surrounding heat (engine/exhaust) and compressor being switched off for very lengthy periods. Removed from car and adequately stored shouldn`t really present any problems
Post by: Nick27 on 22 June 2013, 20:47:17
I think i can do this test myself.
Post by: RobG on 22 June 2013, 20:50:42
Easy enough to do Nick. Jack up N/S front (axle stand) and either run extended cables from battery to comp. or connect 2 probes to plugged in battery charger croc clips and touch relevant inputs on comp
