Omega Help Area => Omega General Help => Topic started by: the alarming man on 23 June 2013, 13:44:58
I have in the past always used the Vauxhall 10w 40 oil but I brought a box of Vauxhall oil yesterday and they have supplied me with 5w 30...so the question is, is the 5w 30 ok to use on a oil change for the omega?? :y
Yep
cheers Rob :y
What price? Fully synth is more expensive than semi - you may well have a real bargain :y
Personally i wouldn't use 5w30 as its a bit thin,might get issues with leaking,seals
I use the 5w30 in mine. No problem at all. It's the specified oil for the 2001+ cars, after all. Mine's no spring chicken at 148K now, and completely oil tight.
Mine is 204k, and never needs an oil change, it uses the constant loss system ::)
I really must fix that leak :-[
What's the current theory on where it's coming from? (https://dl.dropboxusercontent.com/u/26795734/Smilies/kaffeetrinker_2.gif)
Possibly where dipstick enters block, but I failed last time I attempted to remove dipstick tube, and time was tight (but not as tight as that bloody tube ;D)
I use the same system on mine. Trouble is, I keep forgetting to check it :-[
It reminds me a soon as it starts rattling, then I chuck 2 litres in it ::)
The slightly disturbing thing is that I have yet to see the oil pressure light come on :-\
Mines about half a litre every 2 weeks or so. What I don't understand is that half litre always ends up on my drive. Why can't it drop some in other carparks, and down the road?
::) ;D ;D ;D
Just place a tray under it on your drive, then every fortnight, filter it for insects, cats and small children and reuse :y
do it when engine hot--but wear gloves-comes out quite easy then ;)
No, he just waits for me to drive over to fix his car clean up the mess, sills and under side by rolling around under the car while its on said drive. Usually drives the car through a field full of cow shit first too. >:(
Yeah, let me know, so I can detour to a farm first.
I always get a warm feeling when I see you crawl out with a bit of straw stuck in your ear, smeared in cowshit. I know its childish and purile, but it always lifts my spirits...
You are one sick puppy!
