Omega Help Area => Omega General Help => Topic started by: jereboam on 08 July 2013, 10:55:21
Title: Another question
Post by: jereboam on 08 July 2013, 10:55:21
I've been moaning about the ABS/ECU problems on my car, and occasionally mentioned that the power steering and gearbox have been playing up.
Could these problems all be related? And caused by some wiring problem?
The thing is that the power steering stopped for a while a couple of days ago at the same time as the speedo was out and the ABS and TC lights were on.  Then very suddenly it all came back at once.
A few months ago I had to have the heater matrix replaced, which meant that the dashboard had to be dismounted.  I wasn't happy with the garage that did the job for a variety of reasons, and now I'm beginning to wonder whether they put the thing back together properly.  Could there be a multi-purpose connector not properly seated somewhere behind the dashboard making intermittent contact?
Title: Re: Another question
Post by: tigers_gonads on 08 July 2013, 11:49:13
Possible  :-\
At the end of the day, its all speed sensor related  :-\
Post by: Johnny English on 08 July 2013, 11:56:24
Yes, something that common in all : either a multi-connector or the ground cable.
Post by: Marks DTM Calib on 08 July 2013, 12:08:03
Yes as the ABS system provides the speed signal for many systems including the power steering
Post by: jereboam on 09 July 2013, 10:21:24
Hope it's not a stupid question, but why does the power steering require a speed signal?  Presumably it needs to do less work at higher speeds, but since steering wheel movement significantly reduces with speed, I would have assumed it was self compensating, if you see what I mean.
The fault occurs most often when I've just started or re-started the engine.  As far as I can recall, it can occur when the ABS/TC lights aren't on.  Obviously, since the car is virtually stationary, I can't say whether it is associated with the speedo problem, but since that is definitely associated with the ABS/TC lights, it would be the same.
Post by: Kevin Wood on 09 July 2013, 10:45:27
Power steering assistance is reduced with increasing speed. If you had the same level of assistance at motorway speeds as you have when parking it would be a bit twitchy.
When speed signal is lost, it defaults to a low level of assistance, I.E. steering becomes heavy.
