Omega Help Area => Omega General Help => Topic started by: glennyboy on 25 July 2013, 08:56:58
Title: fault code
Post by: glennyboy on 25 July 2013, 08:56:58
Morning all can anyone help please ive just had rac come and find out why engine light was on the fault code was po420 any ideas what it could be also is car ok to drive it seems ok thanks :y
Title: Re: fault code
Post by: JamesV6CDX on 25 July 2013, 09:01:01
Standard cat below efficiency code.
Common and nothing to worry about. Did he clear the code?
I'm amazed the Rac came out to that! You could have done it yourself with a cheap code reader, or even for free with the pedal trick :y
Post by: glennyboy on 25 July 2013, 09:05:05
I know i just called them out i didnt know what it could be so the rac man they carry the laptops done a check so nothing to worry about oh good  :y
Post by: Entwood on 25 July 2013, 10:20:17
Did he clear the code ???
If you search here for 0420/0430 you'll find it a common enough problem, and is nowt to worry about in itself ...... BUT ....
If the light is on and stays on it is now masking any other problems that may arise, that could actually be very much more important .. SO...
A cheap code reader/resetter that will allow you to check the codes then put the light out is a worthwhile investment. You can now get one that will work, via bluetooth, with a free app on an android phone, for less than £20. Does little else of use, and is not quick, but will allow you to read codes, check what they mean, then reset if not important ....
0420/0430 .. it's not "IF" they occur .. its "when" they occur .....  :)
Post by: chrisgixer on 25 July 2013, 10:31:41
And... Its the PRE cat that has a low efficiency problem.( NOT the the main cat, which is working fine and cleaning all the nasty gases as it should so the mot won't be affected by that code)
But I thought it needed both codes present to bring the light on. :-\
Post by: glennyboy on 25 July 2013, 11:44:02
Rac man did clear code for me  Good old rac  :y
Post by: Entwood on 25 July 2013, 13:20:00
Nope .. either 0420 or 0430 will bring the light on .. :) For some reason I get 0430 more than 0420 .. :), and I expect to get one about next wednesday .....  :)
Post by: chrisgixer on 25 July 2013, 13:47:47
Strange I have 0420 regularly on mine, but no light.  ...yet. ;D
Presume then its measuring up to a certain threshold...? :-\
Post by: JamesV6CDX on 25 July 2013, 15:09:00
I think it has to 'see' the fault so many times before it puts the light on. If it only very occasionally sees it, it will log an 'intermittent' code in the ecu, which is detectable via a code reader, but doesn't put the light on. I think ;D :y
Post by: Marks DTM Calib on 25 July 2013, 16:17:46
And still not voluneers have come forward to try the new relocation technique with exhaust in situ
Post by: chrisgixer on 25 July 2013, 16:24:52
I'll put me hand up Mark.
We need a site to operate though. There must be 20 odd cars that need sorting.
Post by: chrisgixer on 25 July 2013, 16:25:15
(Lucky Mark ;D )
Post by: chrisgixer on 25 July 2013, 16:27:29
Provided we take the engine ecu out, I guess I have most of the other electric components in the mv6 if needed.
Post by: chrisgixer on 25 July 2013, 16:28:30
Plus I have another pair of cats here for a dry run. And they do bring the light on.
Post by: chrisgixer on 25 July 2013, 16:32:28
Started a thread in car chat. :)
Post by: TheBoy on 25 July 2013, 21:20:51
To the OP, do NOT replace the cats. Ever. Anyone tell you you need new cats, kick 'em in the nads and walk away. Its the starting cat (often called pre cat) thats tired, not the main cats. So it should pass emissions if you get the light out.
Pattern cats are complete utter shite, and will not solve the issue.
The answer is relocating 2 of the sensors.
