Omega Help Area => Omega General Help => Topic started by: Ecr33 on 25 July 2013, 20:42:57
Title: Best diff/driveshafts for drifting
Post by: Ecr33 on 25 July 2013, 20:42:57
Hi guys Im new here.
I wonder which diff and driveshafts is the best and will handle most power for omega b?
Title: Re: Best diff/driveshafts for drifting
Post by: TheBoy on 25 July 2013, 21:32:21
As far as I know all the driveshafts and prop shafts are the same across the range (prop varies between manual and auto gearboxes).
Diff, guessing you'll want LSD. Again, I thing they are (strength wise) the same across the range, though ratios vary with engines and gearboxes.
Post by: Ecr33 on 25 July 2013, 21:48:25
Thanks for answer. So the mv6 and 2.0 have all the same dimensions?
