Omega Help Area => Omega Electrical and Audio Help => Topic started by: m.ian on 28 July 2013, 19:18:18
Title: Tow bar Electrics Grey Socket
Post by: m.ian on 28 July 2013, 19:18:18
hi,
Noticed in car manual that there is a fuse (fuse # 27) for a "switched" power feed for the the above.
Does anybody know where the wire for this is or how to make the connection?
Thanks
Title: Re: Tow bar Electrics Grey Socket
Post by: Andy B on 28 July 2013, 21:10:45
hi,
Thanks
it's the thick red wire in the towbar electrics socket somewhere in your 'boot' ....... not sure where it is in an estate  :-\
Post by: Entwood on 28 July 2013, 21:16:23
hi,
Thanks
Not "switched" in my motor .. permanently live .. :)
Post by: Andy B on 28 July 2013, 21:18:37
hi,
Thanks
No, it's not in my car either  ;) ....... I didn't read all the question. However, I'me sure the manual says a permanent 12volt  ???
A misleading question!  ;D ;D ;D
Post by: Andy B on 28 July 2013, 21:21:26
hi,
Thanks
If you want a 'switched' live for your fridge & caravan battery charging, you need a voltage sensitive relay ie one that switches when it senses there's more than 12volts going to it, when the engine is running.
Post by: m.ian on 29 July 2013, 10:24:21
Fuse # 5 is for the continuous live for the trailer and yes it is the large red wire in the boot.
Have found that but want to find where fuse #27 out put is.
Post by: RobG on 29 July 2013, 10:38:27
hi,
Thanks
Self levelling suspension & rear acc. socket ???
Post by: m.ian on 29 July 2013, 14:37:02
discovered that this has nothing to do with the trailer socket  :'(
Thanks for the input anyway.
Post by: henryd on 29 July 2013, 14:40:15
If you use one of the smart charging relays to connect up it will be a "switched" feed anyway as the relays don't run fridge/battery charging until they detect charge voltage after start up :y
