Omega Help Area => Omega General Help => Topic started by: m.ian on 29 July 2013, 14:40:07
Have recently noticed that when I select reverse sometimes the reversing lights and parking sensors are not activated!
Can anybody give instructions on how/if this is adjustable?
Note reverse gear is engaged OK
Tried wiggling gearshift
It'll probably be the selector switch starting to play up. Might be worth removing it and giving it a clean before it starts affecting the gearbox function as well.
Indeed, have a look around the selector switch
OK is there instructions on the forum to do this?
Yep - in maintenance guides :y
Its bolted to side of box, partial obscured by starting cat (so don't attemp it if you've been using car ;D). 2 bolts, i large connector, and a nut for the lever.
Ok great
will have a look if it stops raining long enough to do it :y
Ok great
Rain? what the hells that ::)
Ok great
It's pissed it down at times today in this Bury!!! :y :y
