Chat Area => General Discussion Area => Topic started by: Nickbat on 22 May 2008, 23:20:09
Title: Doughnut LPG tank
Post by: Nickbat on 22 May 2008, 23:20:09
Idly looking through LPG conversions, I came across this page. I rather like the idea of the doughnut tank (top left), except what do you do about the spare wheel? (I know, don't carry one...and hope for the best!  ;))
http://www.gascarco.com/gallery/album38
Title: Re: Doughnut LPG tank
Post by: Gaffers on 22 May 2008, 23:21:39
carry a can of tyre weld  :y
Post by: Entwood on 22 May 2008, 23:30:16
As said .. carry an aerosol can of "gunge" .. but you risk destroying your tyre, and these ONLY work for small leaks.. rip the tyre and you are stuck.
Also .. my research indicated the biggest torodial tank was about 45ltrs gas .. now I'm getting about 4.0 miles/litre on gas .. which gives 180 miles at best, probably less when towing/around town .. possibly less ... and there are not THAT many LPG places ... so you could end up using petrol whilst looking for LPG .. NOT a cheap solution.
It was for these, and other, reasons I opted for the large 80 ltr (68 ltr gas) cylinder tank .. gives a range of around 250-300 and I still have a spare wheel.
OK  I've lost 1/3 of the boot.. but it's a damned big boot to start .. :)
Post by: Andy B on 22 May 2008, 23:32:08
It's not that big that I'd like to lose a third of it, I often fill mine when we go away with the 'van as that's where I carry the awning. Besides, a Senator's was bigger!  ;D  :y
Post by: Vamps on 22 May 2008, 23:44:02
My daily car is a Citroen C4 7 seat thing :-/ :-[
It does not have a spare wheel at all, it has a can of tyre repair / gunge sturr and a small compressor. :y
Post by: Nickbat on 22 May 2008, 23:49:28
Fair comment, but the number of LPG stations is on the increase and it wouldn't be too difficult to plan refuelling options before setting out.
Post by: Jay w on 23 May 2008, 08:13:12
Looking at the pictures they do some pretty good quality installs there, a couple of those pics have given me some ideas for my install this weekend  :y
Post by: Elite Pete on 23 May 2008, 08:49:42
Im considering 2 tanks a doughnut tank and a normal tank so when I need my boot pace (half a dozen times a year) I remove the large tank from behind the seats. I dont think an installer would do this for me, but theres nothing to stop me doing it ;)
Post by: Kevin Wood on 23 May 2008, 09:35:14
I looked long and hard at doing this. As said, 45 litres usable is about the limit for a vertical tank in the space available. Even that was looking marginal from my measurements and I wouldn't have liked to order one without offering one up to check the fit.
They are also quite fussy about orientation (must be true vertical) and quite a tricky install. I came to the conclusion that it probably wasn't worth the hassle. I will probably go for a cylinder when I eventually decide enough is enough.
What to do with spare wheel is easy enough. Put it in the boot. Mine's empty 90% of the time anyway. The odd time you travel with it full, chance it on some tyre weld.
