Omega Help Area => Omega General Help => Topic started by: SMD on 03 August 2013, 18:15:53
Title: Misfire codes - but no misfire present
Post by: SMD on 03 August 2013, 18:15:53
After filling up with fuel today the engine management light came on. Car was pulling as normal, no signs of misfire/power loss so I thought the 0430 and 0420 returned. Car felt a bit, well different on start up but not rough before heading to the pumps
But it turned out to be
0300
0301
0306
Cam cover gaskets and spark plugs were changed were changed last year. GM fitted.
Title: Re: Misfire codes - but no misfire present
Post by: Andy B on 03 August 2013, 19:25:28
0300
0301
0306
Have you pulled either or both your coil packs yet to check the plugs aren't swimming?  :-\  :-\
Post by: SMD on 03 August 2013, 19:39:10
Not yet, but seeing as it was changed last year I assume (hope) its not swimming in oil
Post by: SMD on 03 August 2013, 19:40:57
Just want to add, light goes out when car is started
Post by: chrisgixer on 03 August 2013, 23:32:55
...did it rain the night before this happened? Or at any point before the miss fires?
 How long was the car used from cold before filling up with fuel...?
0301 is the cylinder nearest the air box. You'll find a map of cylinder numbers moulded on the cam cover near pot 1.
There's a guide on removing coil pacs in maintenance I think. Basically says to remove two plenum bolts and screw those into the brass inserts on the cp to pull it out. Avoids damaging them.
Check for oil and re torque the plugs to 25nm while your there. They can come loose.
...also check for water or signs of water dripping off the scuttle. Rust or white residue are clues. The wiper spindle is right above pot 5 and the scuttle join is right above pot 6. So if it rains water can get into the ignition system...
Takes some pics of the plug wells and coil pacs under side too. Post em up. Look for cracks in the cp's around the base above the rubbers.
....or it could just be a dodgy batch of fuel ...or the tank was really low?
Post by: SMD on 04 August 2013, 01:09:56
Thanks Chris.
Yes it was raining last night and heavily yesterday morning. The car was used for max 10mins from startup to stopping at fuel pump. Last tank of fuel was V power nitro and there was just under a 1/4 tank left
Driver side looks easy. How do I de-pressurise fuel lines? Remove fuse to make it stall, as per fuel filter replacement?
Passenger side worries me. Loads of stuff to potentially break  :-\
I have a small coolant leak that isn't the HBV. If the leak is inside the V, could coolant have found its way to the coilpack?
Post by: jonny2112 on 04 August 2013, 05:35:19
Don't think there's any need to de pressurise for this task, and certainly the driver side is easier. On the passenger side you may find it easier to remove the plastic cable tray, which makes the wiring loom a bit more pliable, so you can manoeuvre it out of the way a bit more to aid pack removal. As Chris says, use two plenum bolts to remove the packs. That'll become clearer when you see the threads, having removed the coil pack bolts, and really does help.
I wouldn't have thought a leak in the V could affect the coil packs, but someone will know for sure.
Post by: chrisgixer on 04 August 2013, 09:23:36
V is much lower than the heads so there's no chance of coolant getting on the cp's from there. HBV might spray it in an odd direction but I've never know it get on top of the engine personally, as the hbv is at the back and lower down it its on its peg.
 Re water or coolant residue on the cam covers, your looking for white scale marks for rain water, or if its coolant the residue the colour will be from vx red coolant so looks a pinky brown colour...or whatever coolant type you have in there.
 Once the water gets in the plug wells it will turn rusty from the steel on the plug base where its boiled/evaporated off.
I'd suggest just doing the drivers side for now and see what you find.
Re fuel rail, I never bother, just undo the fuel line unions/nuts above the drivers cp and have a rag ready to cover the joint to stop the spray and catch the excess. 17mm and 19mm spanners iirc?
Post by: chrisgixer on 04 August 2013, 09:27:34
Re the rag, leave it tied up around the fuel line bracket on the manifold, to catch fuel , it has a habit of dribbling out of there just at the wrong moment.
Make sure you don't get fuel in your eyes btw, it stings like fook. But you should be fine with a rag around the spanner as you undo the nuts.
Post by: SMD on 04 August 2013, 12:49:22
Thanks for the replies. I noticed from the spark plug replacement guide that it is possible to get the coil pack out without disconnecting the fuel rail because the spark plug necks are flexible.
How tight should I do the bolts up when replacing the coilpack?
I had a quick look for water stains and I did notice a spot of dried water residue about 10mm wide on top of plug 1  :-[
Post by: SMD on 04 August 2013, 15:14:13
Plug wells are clean and dry although is that oil in there? I havent got the right tool to take out a plug or check if it is tight. What do I need? I have nothing deep enough to fit over a spark plug! Coil pack looks ok to me. Thoughts?
(http://i1059.photobucket.com/albums/t440/Zaf_Yousef/IMAG0865_zpse272ee8b.jpg) (http://s1059.photobucket.com/user/Zaf_Yousef/media/IMAG0865_zpse272ee8b.jpg.html)
(http://i1059.photobucket.com/albums/t440/Zaf_Yousef/IMAG0863_zps766b6f9d.jpg) (http://s1059.photobucket.com/user/Zaf_Yousef/media/IMAG0863_zps766b6f9d.jpg.html)
(http://i1059.photobucket.com/albums/t440/Zaf_Yousef/IMAG0870_zpsfd0be5b5.jpg) (http://s1059.photobucket.com/user/Zaf_Yousef/media/IMAG0870_zpsfd0be5b5.jpg.html)
(http://i1059.photobucket.com/albums/t440/Zaf_Yousef/IMAG0864_zps71428e9d.jpg) (http://s1059.photobucket.com/user/Zaf_Yousef/media/IMAG0864_zps71428e9d.jpg.html)
(http://i1059.photobucket.com/albums/t440/Zaf_Yousef/IMAG0873_zps23889269.jpg) (http://s1059.photobucket.com/user/Zaf_Yousef/media/IMAG0873_zps23889269.jpg.html)
(http://i1059.photobucket.com/albums/t440/Zaf_Yousef/IMAG0874_zps8beeac31.jpg) (http://s1059.photobucket.com/user/Zaf_Yousef/media/IMAG0874_zps8beeac31.jpg.html)
(http://i1059.photobucket.com/albums/t440/Zaf_Yousef/IMAG0869_zps16b6b5fb.jpg) (http://s1059.photobucket.com/user/Zaf_Yousef/media/IMAG0869_zps16b6b5fb.jpg.html)
(http://i1059.photobucket.com/albums/t440/Zaf_Yousef/IMAG0871_zpsb2917b49.jpg) (http://s1059.photobucket.com/user/Zaf_Yousef/media/IMAG0871_zpsb2917b49.jpg.html)
(http://i1059.photobucket.com/albums/t440/Zaf_Yousef/IMAG0872_zps17e2e15b.jpg) (http://s1059.photobucket.com/user/Zaf_Yousef/media/IMAG0872_zps17e2e15b.jpg.html)
(http://i1059.photobucket.com/albums/t440/Zaf_Yousef/IMAG0868_zpseb0a38d8.jpg) (http://s1059.photobucket.com/user/Zaf_Yousef/media/IMAG0868_zpseb0a38d8.jpg.html)
(http://i1059.photobucket.com/albums/t440/Zaf_Yousef/IMAG0867_zps92622e91.jpg) (http://s1059.photobucket.com/user/Zaf_Yousef/media/IMAG0867_zps92622e91.jpg.html)
Post by: omegod on 04 August 2013, 15:18:34
Dryest plug wells I have seen to be honest! usually at least a bit of oil.
I have some coil packs if you need some, but if it is driving ok  :-\
Post by: SMD on 04 August 2013, 16:00:06
Cool, I thought there was a bit of oil around the spark plug. So how does the coil pack look to you? Mine is a 3.2 by the way so would one from a 2.6 fit?
How tight does the coil pack bolts need to be? I haven't put it back yet.  ;D
Post by: albitz on 04 August 2013, 16:06:40
Also the cleanest plug wells I have ever seen.Coil pack looks fine to me.2.6/3.2 coil paks the same. There may be a torque figure for the coil packs,but if not just tighten them until you fell them get tight at the end of the thread (finger tight) then nip them up slightly more with a socket (quarter of a turn approx.) so they don't vibrate loose.
Need a spark plug spanner for checking tightness of plugs. Normall one one in every socket set. :-\
Post by: SMD on 04 August 2013, 16:25:04
Thanks for the replies. I just done it up hand tight and nipped it to 8nm. As said above, no running issues so will see if code self clears
Initial start was about 700rpm but now idling at 500rpm
Post by: chrisgixer on 05 August 2013, 09:03:00
Does the Halfords socket set not come with a spark plug socket anymore? :(
Unless the plugs are loose, there's nothing wrong there. Its all in very good condition.
Other than a hose on the windscreen with the bonnet up to see where any water could be coming in, I would just drive it and see if the issue re occurs.
Post by: chrisgixer on 05 August 2013, 09:05:01
Could the change back to normal unleaded have upset the engine management for a second or two? :-\
Post by: SMD on 05 August 2013, 09:49:46
Refilled with the same grade petrol. New halfords set doesn't come with spark plug socket, as far as I can tell.  :(
Do these codes self clear or do you need a tech 2?
Post by: henryd on 05 August 2013, 12:53:05
any 16mm long reach socket will remove plugs with suitable extension :y
Post by: SMD on 05 August 2013, 18:20:39
It just rained quite heavily so I thought it would be a good opportunity to check if the scuttle was leaking. Drivers side is fine but passenger side was dripping over the multiram connector and the camcover bolt at the back. Not a huge amount though  :P
Post by: SMD on 06 August 2013, 08:07:44
Where does the water actually leak through? Windscreen to scuttle seal looks ok  :-\ Where are the usual culprits? When the water runs down the windscreen and into those little squares on the scuttle, does it collect at the bottom and flow into the drain hole by the cabin filter?
Post by: chrisgixer on 06 August 2013, 10:09:20
Spindle holes, the join in the two half's by the scuttle drain, and the seal can look intact but be completely un lipped from the screen.
Soggy sponge on the underside is also also a clue. If that wet when squeezed, its leaking.
I didn't have a silicon seal when I sealed mine, so used cam cover goo. A big bead along the top of the metal scuttle replacing the draft excluder there, and around the fealt(?) washers around the spindles. After grabbing the scuttle and pulling/wiggling to make sure its secured to the screen first.
Yes, apart from the drain on the drivers side, it should all end up in the scuttle drain under the pollen filter. The drain itself should flow freely, not be blocked, of course. :)
Post by: SMD on 06 August 2013, 10:24:45
So can I fill the spindle holes with silicone? I have some camcover and grey sealant left over.
The two pieces of scuttle, do they leak where they meet? Surely by its very design, it will always let water through as there isn't a seal of any sort. Besides, I snapped the little tab that slides in to the other.  :'(
Post by: chrisgixer on 06 August 2013, 10:33:03
The join itself is over the scuttle drain, so that doesn't matter. The important bit is stoping the water running back into the engine bay from that metal lip that the plastic scuttle sits on, where the draft excluder is.
I did my spindles with scuttle in place. Just squeeze some goo under the plastic and over the felt washer thingy, to glue the two together, effectively. Making sure its dry first :)
Edit, as far as keeping water out of the engine bay goes.... Iirc the passenger side section isn't actually needed, from memory...? :)
Post by: SMD on 06 August 2013, 10:44:16
Thanks, will have a look and report back  :y
