Omega Help Area => Omega General Help => Topic started by: aiden on 04 August 2013, 15:07:02
Title: wont start
Post by: aiden on 04 August 2013, 15:07:02
hi, car wont start clip codes says 37 is this a censor or something else
  aiden
Title: Re: wont start
Post by: dbug on 04 August 2013, 15:31:35
What engine and year?  Assume 2 digit code its a non-dbw.
Code 37 - not listed.
common reason for non starting V6s is failed crank sensor (usually 19, but sometimes doesn't throw a code).  Sure code not 31?
Post by: aiden on 04 August 2013, 15:39:19
hi , 2.5 1998, trying clip test again , aiden
Post by: aiden on 04 August 2013, 15:46:34
hi , it could be code 73, the car turns over but not firing,  censor? aiden
Post by: zirk on 04 August 2013, 15:56:37
Whip the petrol pipe feed off (Drivers side of Engine), on the FL it wont piss petrol out whilst cranking if the Sensor has gone, fairly sure yours will be the same.
Post by: RobG on 04 August 2013, 15:57:18
73 is MAF, but given symptoms, crank sensor as said (code 19)
Post by: albitz on 04 August 2013, 15:59:53
73 is MAF (mass airflow voltage low) try unplugging the MAF sensor and see if car will start. MAF is more likely to cause it to run rough than not start afaik. Cause of non running is often duff crank sensor which wont always show a code.Try unplugging MAF first though and see what happens.
Post by: aiden on 04 August 2013, 16:38:40
hi, its code 73 strong smell petrol after turning over, thinks the maf is ok, must be crank censor, aiden
Post by: albitz on 04 August 2013, 16:45:05
Un plug the MAF and then see if it will run.
Post by: aiden on 04 August 2013, 17:21:49
hi, disconected maf and it started reconected and still running, do i need to get a new maf or will it be ok ,
 thanks for your help
Post by: albitz on 04 August 2013, 17:26:36
Sounds like the MAF is on the way out.Best to replace it imo. I believe they are pretty expensive from VX. Might be worth posting a wanted ad,or contact someone who is breaking a suitable car. I don't have one myself,but someone else might. :y
Post by: RobG on 04 August 2013, 18:06:56
3.0 MAF should be the same http://www.omegaowners.com/forum/index.php?topic=116235.0
Post by: PLANETNZ on 05 August 2013, 08:41:56
I just replaced my MAF with a new non OEM direct from China, total cost $70nz (about 30uk pound inc freight). I know everyone here will moan! but for the price its worth a try! PS mines working fine
