Omega Help Area => Omega General Help => Topic started by: andy_myers on 06 August 2013, 09:28:26
My indicator stalk on my 2.6 v6 doesn't cancel itself I have a replacement stalk. How do I replace it? Also do I need to get the cruise control programed in?
Remove the shroud from the top of the steering column/behind the steering wheel ...... 2 screws behind a cover each behind the wheel (turn the wheel lock to lock & you'll see them) & 2 or 3 :-\ screws underneath, and unscrew the column tilt lever. Both stalks just clip into the top of the column.
If you had Cruise before your still have after replacement, assuming its the correct stalk. ;)
99% of the time its the piece behind steering wheel-NOT stalk :-\
A 'new' indicator fixed my none self cancelling Astra indicators - even though there didn't look to be much wrong with the old one :-\ ...... same set up as the Omega. :y
I have had 3 migs with same problem-and all of them had to have that part behind steering wheel :( -one of them was my one two months ago >:(
IME, its usually the stalk. Not sure I've ever seen one that wasn't....
