		Omega Help Area => Omega General Help => Topic started by: berserkerboy on 09 August 2013, 17:28:24
				Hi all
Just had a hell of a job getting the top bolt of the drop link off. The problem was that the bolt was rotating as I tried to undo the nut. Should it be doing this? Managed to remove by getting some plumbers pliers around the metal by the rubber grommet but am concerned I wont be able to get it all back together.
				There should be a flat on the drop link sized for an open ended spanner to stop it spinning ;)
As above or possibly an Allen key or Torx hole in the end of the threaded part if they've been changed previously. I've only ever removed them to bin but I know what a sod they can be if they have no inner nut.  :y
When the thread spins, it twists the ball and gaiter but not sure if it ruins it. As said, I normally remove to bin, so I just pilot drill the nut in a couple of places and whack a small punch in one of the holes to split the nut.
				Oh yeah. See the flat now. Couldn't while it was up in the gloom.
Thanks
				 ;) ;) :y
