Newbie Area => Newbie Welcome Area => Topic started by: newboots on 19 August 2013, 17:39:53
Title: new memeber with Windscreen washer problems
Post by: newboots on 19 August 2013, 17:39:53
Hello all
New to the forum, and looking for help
Vauxhall Omega 2.2 the windscreen washer doesn't pump through to the screen.  I've changed the pump and when placed in water it work and pumps away.  When i place it back on the water tank nothing is coming out !!
Am i missing something?
Title: Re: new memeber with Windscreen washer problems
Post by: dbug on 19 August 2013, 18:15:53
Welcome to OOF mate  :y
Check pump power lead  ;)
Post by: TheBoy on 19 August 2013, 18:39:20
Can you hear pump? If so, remove pump, then remove the rubber grommet/filter that the pump nozzle fits in, and clean all the white gunk out of it.
Post by: TheBoy on 19 August 2013, 18:39:43
The white slime is a sure sign of too weak screenwash fix...
Post by: flyer 0712 on 19 August 2013, 22:03:22
Hi and welcome  :y :y
Post by: noel on 19 August 2013, 22:19:07
hi & welcome :y
Post by: newboots on 20 August 2013, 00:13:00
Pump is good and runs, the outlet to the washers is spraying weakly and has white foam.  I'll clean out the filter tomorrow and see if that works
Post by: Jusme on 20 August 2013, 13:00:16
Hi, Welcome to the OOF.  :y
Post by: steve6367 on 20 August 2013, 13:57:11
Welcome :-)
Post by: sandune on 20 August 2013, 15:16:44
Hiya welcome aboard :y
Post by: PAULCDX on 20 August 2013, 18:02:17
Hi and welcome to the forum  :y
Post by: newboots on 20 August 2013, 18:32:39
I think that sorted it.  Although the water tank is pretty thick with sludge, could include frogs, but i got it working.   Splashed in a large dose of clearing fluid and see if that does the trick
Thanks for the help
Post by: Cliffo B on 21 August 2013, 00:52:31
Hello,welcome to the Forum :y
Post by: Mr.OmegaMan on 21 August 2013, 01:23:54
Welcome to OOF  :y
Post by: x25dt on 21 August 2013, 18:53:29
Hi, Welcome to OOF  :y
Post by: Lizzie_Zoom on 26 August 2013, 13:34:21
Hello and a warm welcome to you! :y :y
