Chat Area => General Discussion Area => Topic started by: SMD on 25 August 2013, 21:31:59
Title: sky broadband settings
Post by: SMD on 25 August 2013, 21:31:59
Is it possible to block certain devices such as smartphones/tablets etc from accessing the web wirelessly? At the moment I have the laptop, a few mobiles, and the sons tablet connected. I want to limit the time the tablet is connected and block it when needed from connecting. How can I do this without changing the password all the time?
Title: Re: sky broadband settings
Post by: tunnie on 25 August 2013, 21:39:38
http://help.sky.com/security/protect-your-family/mcafee-parental-controls (http://help.sky.com/security/protect-your-family/mcafee-parental-controls)
 :y :y :y
Post by: SMD on 25 August 2013, 22:11:42
Not really a big fan of McAfee. Is this just parental control or must you install the antivirus/spyware ?
Post by: tunnie on 25 August 2013, 22:13:14
Access is controlled via the Anti-Virus, fully automated. There are other options like limiting on MAC address, but thats all very manual
Post by: SMD on 25 August 2013, 22:17:52
ok, thanks. will give it a go.  :y
Post by: AndyRoid on 25 August 2013, 23:29:45
 :y :y :y
I doubt that will help in this case T, unless of course you can install it on the aforementioned "smart" devices.
What the OP needs is a router with a half decent firmware that allows you to specify access times on a per device basis.
Post by: Marks DTM Calib on 26 August 2013, 16:11:01
Better routers allow you to configure access times against fixed IP address's.
So configure the IP address's (which is done based on MAC address's amd is useful as a security feature in itself) adn then add a rule for that IP.
Assuming the router will do it (as the bogo cheap ones dont)
Post by: AndyRoid on 26 August 2013, 21:45:08
That means SMD has to assign a static IP to the device, and you know it won't take long for the kid to figure out how to drop back to DHCP and get back on  ;)
I've just had a thought, you've hit the nail on the head with MAC addressing......if the Sly router lets you set access times based on MAC address, then it won't matter how smart the kid is because he won't be able to change his MAC.
A much cheaper, quicker, and easier solution was in the title of the software that Tunnie posted IMHO.........parental control  ;)  ;D
