Omega Help Area => Omega General Help => Topic started by: arth on 26 August 2013, 10:59:49
Title: Problem with the window
Post by: arth on 26 August 2013, 10:59:49
Hi:
The driver's windows is begining to have some problems, the thing is that I do not know wether the problem is of the motor or the switch, I want to take out the switch from the center console and check it, just moving the connectors from the from front to the rear windows, if the window works will be a problem of the switch, if not,  of the window's motor
Does anybody knows how to take out the switch?, Do I have to take our the center console near the hand brake to get it?
Thanks
Antonio
Title: Re: Problem with the window
Post by: TheBoy on 26 August 2013, 12:01:22
IIRC, you can get yo it with minimal removal.
Lift gearstick gaitor (pull it up at the front), then you can press up from underneath, in same way as auto indicators
Post by: arth on 27 August 2013, 10:22:36
Thanks Theboy, yesterday I could do it but I could not reach the cable connectors, I am sure it is a problem of the switch because when I press for down it sounds a "click" in the windows and it works, but when press up, sounds nothing, sometimes it sounds and the windows works
Thanks
Antonio
