Chat Area => General Discussion Area => Topic started by: Varche on 04 September 2013, 20:26:00
Mine works well enough but the batteries(rechargeable) on the outdoor sensor have needed charging once already since receipt.
Only complaint is the visibilty of the numerals. It would be nice at midnight to see if it less than 25 deg C outside yet!! maybe there is a way of doing that?
I breathed on the indoor part last night and was surprised (but not amazed) to see the humidity go from 59 to 62%. Must have been the Rioja. :y
How are you getting on with yours?
Still working, Not the best but good enough considering its price :y
It would be nice at midnight to see if it less than 25 deg C outside yet!! maybe there is a way of doing that? ......
Breifly press bottom left button ....'snooze' and it back lights the display
Was surprised it had such a feature when stumbling across it :o
I only had it a day and the leaflet got binned. The tea making button in the morning is still a good find though. ;D
Got the internal display sat on top of the room thermostat in the dining room.....room stat says the temp is 23C, weather station says the the temp is 21C.....so one of them isnt correct....but i guess they both could be off by 1C :-\
Mine is still in its box........... :( :-[ :-[
And, of course, that 1° is really important. ::)
Well you keep saying that 1cm is important, an extra one makes all the difference........ ;) ;)
I've never, ever mentioned centimetres, it's feet I usually speak of. ::)
Took mine on hol's to see just how hot that bloomin caravan gets - one evening, when It was 39 outside and 42 inside during the day, the outside sensor failed and has not worked since :( :'(. If that had been the c/h stat that would have been 44 in :o :o :o
