Omega Help Area => Omega General Help => Topic started by: chappa on 05 September 2013, 20:52:43
Title: drivers exhaust manifold gasket
Post by: chappa on 05 September 2013, 20:52:43
hi there is there any one in the north east who would like to do my gasket and will b paid well ive tried but failed and carnt find a step by step its doing my head in now cheers :)
Title: Re: drivers exhaust manifold gasket
Post by: omegod on 05 September 2013, 20:58:02
Believe it or not that's the easier side , what part of the job are you stuck on?
Post by: martin42 on 05 September 2013, 20:59:27
Drivers side easy ,passenger side,easier to remove head as I found out this evening
Post by: chappa on 05 September 2013, 21:03:17
i can only find 2 bolts tried to remove pipes and things but carnt seem to see any more
Post by: martin42 on 05 September 2013, 21:04:53
There's 7 13mm nuts to remove,after you've removed heat shield
Post by: symes on 05 September 2013, 21:11:48
you got to remove intake pipes and disconnect pipes to egr set up at front of engine--its a pipe just under water/rad hose on drivers side and also remove airbox and water expansion tank---then you can see bolts to heat shield--biggest headache will be water transfer pipe that comes around that side from rear of engine ;) but still is easier than other side :y
Post by: Webby the Bear on 05 September 2013, 21:13:11
 ;D ;D ;D ;D
Post by: martin42 on 05 September 2013, 21:14:41
Well what did you expect from a plumber,lol hammer ,long cold chisel,job done lol
Post by: Webby the Bear on 05 September 2013, 21:17:03
believe me mate, your ingenuity saved us tonight! i'd have been buggerd  :'( so all praise to ya mate thanks very much  :y :y :y
might be worth mentioning..... the downpipe to manifold bolts weren't a size!!!!  :o :o :o
Post by: symes on 05 September 2013, 21:57:58
yes they are-imperial not metric---well on three that I encountered anyway(now coffee tables-sold on)
Post by: terry paget on 06 September 2013, 08:49:26
Right. 16mm loose, 5/8" good tight fit. Very strange.
Post by: Marks DTM Calib on 06 September 2013, 09:03:44
They are metric but there a crimped nut  (as is used to stop them coming loose).
The best fit is a hex socket (which is the tool of choice as standard anyway), from memory the ones used for the spark plugs is a perfect fit.
Post by: biggriffin on 06 September 2013, 10:56:30
5/8 tapped on, lots of heat (blue spanner), or if you dont have heat, try to do the nut up, then undo the nut and lots of squirty oil of your choice, undo and do up, takes time but dles work and saves snapping studs.
Post by: symes on 06 September 2013, 16:56:32
yes 5/8 which when I went to school is 14.74mm so if you got 14.74mm metric socket--it will fit
AND you should only ever use hex sockets anyway--less chance of rounding nut/bolt :y :y :y
Post by: TheBoy on 07 September 2013, 09:41:12
I've always only used metric on the Omega.  I guess if rust has eaten in, it can be any size....
Post by: albitz on 07 September 2013, 09:48:26
When trying to remove these nuts a few weeks ago I tried both metric and imperial sockets,but nothing would fit properly.
When I eventually got the manifolds and down pipes out of the car I removed the nuts using a metric socket. Either 15 or 16 mm (cant remember),but it had to be hammered onto the nut.
As said,its the corrosion,heat etc over time that knackers them a bit so that the correct (metric) socket wont fit properly.
They can be an absolute pig to remove sometimes,and then other times they come of relatively straightforwardly ime Don't know why they cant use brass ones like they did back in the day ?  :-\
Post by: Andy B on 07 September 2013, 09:48:57
Was it?  ::)  ::) That must've been before the current metric system then.  ;D  ;D  ;D
5/8" = 0.625" multiply by 25.4 (mm in an inch) = 15.875mm  :y  :y  :y
Hence some sockets sets include a 5/8" socket or a 16mm socket because there's little difference between the two
Post by: terry paget on 08 September 2013, 10:08:07
I got mine off after heating with blowtorch, with a 16mm socket. Following this thread I tried a 5/8" socket, and it's a better fit. And I agree, why oh why do they not use brass nuts? On my Peugeots they used brass nuts, and they came off sweet as you like. I suppose it's cost Shame on them.
