Omega Help Area => Omega General Help => Topic started by: Muroman on 09 September 2013, 15:40:20
So, I got to my car from work and tried to open door but my door handle broke and now I got to open the door from passenger side...
So the questions are how much I need to take things off from the door? Does anyone have pictures off the handle mechanism?
I don't have carage in my use right now so when I start the project I probably need to finish it at same day if I need to take the lock off?
Is it possible to only change the handle?
-Mika
Too many Weetabix? ;)
Door card off then simple job I think others will confirm
Yes and you can swap the original key barrel over.
-Mika
I'm sure there are no pictures of this, but when you get the door card off & the plastic membrane, you'll see that it is all quite easy & straight forward. :y :y You just need to find a handle of the correct colour. ;)
Happened to me a few years back when the door frame was frosted up and I was being inpatient, got fed up keep climbing over passenger side, so ended end cable tie'ing some cable to the inside handle to the back of the door so I could open it from the drivers rear door. Down side to that was it give me an excuse not to fix for a week or two.
As said Door Card off and replace the Plastic bits. :y
..... and replace the Plastic bits. :y
??? Plastic? ??? It was an alloy section of the handle's hinge that broke on mine
May be due to Weetabix :D
But ye I think I start from car scrap yards trying to get hold of same color handle :) Tomorrow :)
And here's picture of the broken part and I think it's plastic.
(https://dl.dropboxusercontent.com/u/93773592/OOF/WP_20130909_002e.jpg)
-Mika
