		Omega Help Area => Omega General Help => Topic started by: terry paget on 12 September 2013, 07:56:23
				G84GNB
 Reassembling the plumbing. Two pipes emerge from the coolant bridge. The larger, 15mm in diameter, takes the hose to the HBV; the smaller, a brass insert, is 7mm in diameter with a 2mm hole in the end. I cannot find the hose to put onto it. Where does it come from?
				Have found on the bench a long hose that might be the one I am looking for. It might go to the throttle box. Please confirm.
				Yes, throttle body feed, runs along the top of the 2-4-6 head/cam cover
				Thanks. That has solved a mystery.
				I did this job following Haynes, who recommended removing oil pipes. After I had done it, someone said this was unnecessary and unwise. Is that view widely held?
 Yes, no need to remove the oil cooler pipes.
