Omega Help Area => Omega General Help => Topic started by: shaun wilson on 14 September 2013, 19:31:52
Title: My V6 dont like less than a quarter tank
Post by: shaun wilson on 14 September 2013, 19:31:52
This has me stumped.
My meg 2.6 v6 cd has developed what I think is an unusual starting problem. With between a full tank and a quarter tank she starts and runs smooth as normal. When shes on the quarter tank or less she struggles to start, sometimes taking a good couple minutes to fire up but when she does eventually start she runs as normal, smooth and with instant throttle response.
Also, she only struggles to fire up on the quarter tank if shes sat for an hour or 2 but if shes running and I shut her off then turn the key she starts as normal.
Ive replaced the fuel filter and also checked the fuel pump that seems to be working as normal.
Any ideas.
Thanks in advance.
Title: Re: My V6 dont like less than a quarter tank
Post by: Johnny English on 14 September 2013, 20:31:48
If pump and filter are right only one thing left to check it is tank vent valve possibly does not open when should do. Try to start with opened tank cap if right than tank vent valve is source of trouble.
Good luck mate !
Laszlo
Post by: Nick W on 14 September 2013, 20:41:35
A weak or otherwise failing pump seems most likely to me.
Post by: shaun wilson on 14 September 2013, 20:47:12
cheers for info, will try with cap open and if no luck then will go for new pump. Any idea on the cost of a new pump.  :)
Post by: zirk on 14 September 2013, 23:44:09
Any fault codes? (peddle trick). Estate?
Post by: 05omegav6 on 15 September 2013, 00:23:31
Pattern ones cheap enough, but might not last too long... 3 years/120k from my last pattern one...
If an estate, they can get very fussy with low fuel levels ::)
Post by: shaun wilson on 15 September 2013, 11:26:03
No fault codes, shes a saloon model.  Where do I get the pattern fuel from buddy.
Post by: 05omegav6 on 15 September 2013, 12:27:35
Local motor factors best bet, but ring VX for a price first :y
They sometimes surprise with things that you expect to be expensive actually being quite reasonable  :y (and vice versa ::))
Post by: symes on 15 September 2013, 16:04:12
only when on slope were fuel cannot reach pump :y and then that is very low on fuel not1/4 tank :y
Post by: 05omegav6 on 15 September 2013, 16:39:00
You say that ::) mine has previously cut out whilst stopped on a bit of left camber, no light on, and about 60 miles on the range :o
Shoved it round the corner on the starter motor to a level patch and it fired up first time ::)
But usually only happens in the red zone of the gauge :y
Post by: shaun wilson on 17 September 2013, 20:36:03
Ok, little bit weird, sunday evening seen her start first turn of the key so not wanting to push my luck I headed to the garage and put her up to the half tank. Ended up having to take a run to the shops so by the time I got home it was back to the 1/4 mark. Monday morning she started first turn so drove to work which took her to just below the 1/4. On leaving work expecting her to turn over a good few times she ended up starting first turn of the key. So took her the long way home and managed to get the gauge on the red. left her all night and she started perfectly again in the morning. Just wondering if me changing the fuel filter and cleaning and fiddling with the pump has maybe disturbed the culprit.
Post by: symes on 17 September 2013, 20:38:30
:y :y :y :y :y
Post by: Vamps on 17 September 2013, 22:28:51
:y :y :y :y :y
Sounds like it, fingers crossed....... :y :y
Post by: shaun wilson on 18 September 2013, 21:02:20
So far all is good, ive also got her booked in for new timing kit which will put my mind at rest as shes on 81k. Think I need to take out the police lights before I get in trouble though as I have a habit of scaring the life out of the local boy racers  ;D
Post by: shaun wilson on 23 September 2013, 18:20:55
Right, on my way home from work and while on a single track road I pulled over to let an oncoming car passed, while I was in the passing place the car instantly just cut out. the fuel was sitting just at the top of the red and after turning her over a good few times she started and run as normal.
Any ideas guys.
Cheers
Shaun
Post by: albitz on 23 September 2013, 18:30:37
Sounds like crank sensor to me. :-\
Post by: VXL V6 on 23 September 2013, 18:35:50
Agreed
Post by: TheBoy on 23 September 2013, 18:40:36
I was thinking same, but the engine ECU never gets to see fuel gauge, so not sure how that could correlate to it only happening on low fuel...
Post by: Gaffers on 23 September 2013, 19:05:12
either coincidence or a fuel filter issue that is now a crank sensor problem.
Post by: shaun wilson on 23 September 2013, 19:17:52
How easy and how much to replace a crank sensor. Im also away to replace fuel pump with a brand new 1. Thanks for info.
Post by: 05omegav6 on 23 September 2013, 20:06:02
Any ideas guys.
Cheers
Shaun
Fill it up. Then every time you use 1/4 tank, top it up ::)
Might also prolong the life of the pump...
Post by: Andy B on 23 September 2013, 20:09:56
Fill it up. ......
It doesn't do your wallet much good though.
I filled up the Omega yesterday on my way home from work .... £88 and same again tonight in the Merc £100.01  :'( :'( :'(
Post by: TheBoy on 23 September 2013, 20:14:38
Any ideas guys.
Cheers
Shaun
No petrol car should ever be filled up until the misfires start ::)
Hence, I frequently used to walk down the road with a plastic can in my hand ;D
Post by: shaun wilson on 23 September 2013, 20:25:56
Crank Shaft Sensor, just done the pedal thingy and code 0335 flashed, that's the only code that came up aswell. How much to fix and where is the best place to get a new sensor.
Post by: 05omegav6 on 23 September 2013, 20:29:39
Any ideas guys.
Cheers
Shaun
Done that more often than I should have myself :-[
Pretty certain that constantly trying to start it on fumes was what killed the first crank sensor and then the fuel pump :-\
Besides 21-22 litres of fuel still costs £30 regardless of which end of the tank it goes in ::)
Post by: albitz on 23 September 2013, 20:32:51
Crank sensor - ballpark figure £60. Genuine GM only. Follow the guide in maintenance section when fitting the new one. :y
Post by: 05omegav6 on 23 September 2013, 20:34:20
Vauxhall only if you want it to last. But isn't that the one code that doesn't mean what it says :-\
Post by: shaun wilson on 24 September 2013, 18:58:18
New sensor on its way, hopefully once I follow the guide and get it fitted then issues should be resolved. Fingers crossed. Can somebody point me in the direction of the fitting guide.  :)
Post by: RobG on 24 September 2013, 18:59:57
http://www.omegaowners.com/forum/index.php?topic=90540.0
Post by: Entwood on 24 September 2013, 19:01:01
Start here ..
http://www.omegaowners.com/forum/index.php?topic=90633.0
end up here ..
Post by: shaun wilson on 25 September 2013, 21:16:35
Evening,  got home from work to find my new crank shaft sensor awaiting. Gets the trusty tool kit out, locates the sensor on the car, matched the part numbers up and all good, takes the sensor out to find the tiniest bit of rusty fragment stuck to the end of the sensor, the piece must have measured about 1mm by 1mm  ???  so removed it, cleaned up the sensor put it back in and hey presto. She is running like a new car, idles like a purring kitten, starts instantly on turn of the key.
Now my understanding of the sensor is its just a magnet, so im now in the belief that this tiny fragment of metal stuck to the tip of the sensor has been giving false readings and causing my headache. Any info would be appreciated.  :y
