		Chat Area => General Discussion Area => Topic started by: tunnie on 20 September 2013, 18:29:43
				So I know Twiglet had a
mansion  little house built for his fleet, I'm looking at something much more modest  ::)
What would I be looking at, ball park figure, to build a single garage? Current foundations unknown, has pre-fab unit there, so quite possible needs re-doing. Looking at single garage, brick built, standard pitch type.
Something like this, only change, possibly a door on one side.
(http://www.welshbuilds.co.uk/images/img_gar_NewBrick.jpg)
Unlike twiglet, I cannot do any work myself on this, so have to be all done by someone.
Initial research, looking around. Suggests around £10k approx?
Oh planning approval maybe grey area, it's already got one, but it's a different type? It's well set back, can't see anyone complain about a new one. In-fact a replacement would be a lot better! So can't see any issues there.
				Around 5-6.5K labour & materials. Less if using existing garage base/foundations
That's a lot cheaper than I was expecting  :D
Cheers Rob  :y
				<brekk>ing hell!
I'd've budgeted for about a grand + foundations (say 2k tops)
Mind you, i'd've gone for 2nd hand prefab concrete with a 2nd hand insulated steel profile roof.
Tunnie: I'll do you a 10ft x 20ft garage on a 4" slab for 4k, if you're OK with 2nd hand.
50% up front to cover materials. I can bring two lads down next week
				Finger in air rebuild costs for mine are looking approx 20k, so I'd guess 2/3rd for a single. Assuming foundations are sound.
However, as you are rebuilding, the inspectors will insist on replacement foundations due to newer regs.
That implies on planning permission? Surely if theres a garage already there and you pull it down and rebuild, as long as its the same size, why the need for planning?
Starngely enough, I found myself arguing the same point ::)
<brekk>ing hell!
Thanks for the offer  :y
But any replacement will need to be brick build  :)
				A shade wider than that pic, if you're rebuilding, tunnie, so you can get the front (or back) of a car it, and walk around it.
Assuming you dont take a leaf out of my book, and completely fill the garage full of crap, so you can't even get in ;D
To be honest, I doubt the car would ever go in.  :-[
It's going to be motorbike, tools, tyres and such.  At most I'd pop the nose in for oil changes/engine service if its raining.
I didn't mean as overnight storage, I meant for working on the bloody thing ;D
The width of a single garage, you wouldn't be able to get a jack in place to remove the sump plug ;)
The cost of being slightly wider would be minimal (if you keep door the same size), if that is possible.
Ideally I's like to make mine wider, but with my property, its impractical to do so.
Noted  :y
But on my proper car, the 2.2 that is. I can reach sump plug without any need for jacks  ::)
Need to for 3.2 though, so point taken  :y
				I would think it would be around 7-8 grand brick built and 5-6 if blocks are used but then it will need rendering, so probably around the same.
				anything knocked down, burnt down etc to within 10 feet of the ground becomes a new building on errection, sect 123 building act
as far as I know over 40 years the foundation size regs have not changed,
if its under 30 m2 on floor area and detached it will be exempt Building Regs, shedule 2 B Regs
planning decide on the day, and change like the wind in opinion,
But if trees have grown nearby since it was constructed, apparently the foundations have to be built (or modified for rebuilds) to take into account?
Given that tunnie's is a temp prefab, I wonder if it actually has any foundations ;D
I doubt it  ;D
				ahh got that
No, thats building regs....not planning
And building regs pretty much always apply for what is considered a 'permanent fixture' (e.g. a conservatory is not as its considered a shed hence the requriement for it to have external doors between it and the main building which need to be locked when out for insurance purposes), its the planning that may not (and there are caviats for that based on if it is visable from the front plus many other causes)
