Omega Help Area => Omega Electrical and Audio Help => Topic started by: aaronjb on 07 October 2013, 09:27:23
Title: OOF recommended HID bulb supplier?
Post by: aaronjb on 07 October 2013, 09:27:23
It's not my week for cars - took the Omega to Solihull yesterday as the M3 broke down on Saturday and just as we left to head home .. fizz POP and the drivers side headlamp went out.
I have the factory fit HIDs - does anyone have a recommended reasonably priced supplier for replacement bulbs? I know I've read before here that some folks have bought cheapies only to find they don't function correctly .. darned if I can find the post now, though.
Title: Re: OOF recommended HID bulb supplier?
Post by: aaronjb on 07 October 2013, 10:57:39
Thinking about it.. I should probably have put this in Electrical  :-[ :-[
I'll report my own post..  ;D
Post by: 05omegav6 on 07 October 2013, 11:16:35
www.hids4u.co.uk
 :y obviously you want the philips or osram bulbs rather than the chinese copies...
Post by: aaronjb on 07 October 2013, 11:44:19
Cheers Al :y
Thinking about it I better try swapping the ballasts (or bulbs) around first just in case it's the ballast that's gone pop rather than the bulb.
I know they come with a giant warning sticker telling me to only let the highly trained (presumably rubberised) Vauxhall technicians in there so .. anything I should be concerned with beyond disconnecting the battery first?
I don't enjoy 40kV shocks much  ;D (or whatever the voltage is .. I'm guessing)
Post by: 05omegav6 on 07 October 2013, 12:17:02
Pull the headlight unit out, unplugging as you go, pop it on the kitchen table make a cuppa and then dive in :y
Only disconnect the battery if you enjoy reprogramming the clock/ radio ::)
You'll need a small torx bit to undo various screws, but all obvious once the unit is out :y
Post by: aaronjb on 07 October 2013, 12:18:43
Cool, thanks Al :y I'll whip it out tonight.
And I'll take the headlight out later this week..  ;D
Post by: 05omegav6 on 07 October 2013, 12:20:06
Just to add, to check bulb, switch the headlights on, if you can see a faint spark in the dead one then the bulb is toast, rather than the ballast. Should also replace in pairs :y
Post by: biggriffin on 07 October 2013, 12:26:06
Incoming pm :y
Post by: TheBoy on 07 October 2013, 17:46:06
I probably have some spare ballasts if you need them. I have spare bulbs, but seem to recall a slight tinge of pink/purple, so I put my almost melted ones in my "new" headlights.
As to safety, don't be gay :P.  I've never had an issue, but I'd say just be wary of the contacts (which are difficult to touch accidentally)...
Post by: Keith ABS on 07 October 2013, 19:51:42
  I think I used autobulbs direct for my new set. i had previously used Regal autobulbs but they could not match the prices
keith B
Post by: Andre8100 on 08 October 2013, 16:18:27
I am totally agree with you. Its dead easy and pretty difficult to go wrong. You are 100% good here that just to add, to check bulb, switch the headlights on. Should also replace in pairs.
Post by: aaronjb on 08 October 2013, 16:23:52
Well I stared hard at the headlight last night and had Amy switch them on - nothing.. I didn't see even a hint of a spark in there, which seems to indicate ballast rather than bulb.
Must swap them over and see what's what..
Post by: 05omegav6 on 09 October 2013, 15:43:41
Got a spare ballst here if required :y
Post by: aaronjb on 10 October 2013, 12:08:40
Thanks guys :)
I had a sudden thought today - I wondered if (logically) the headlights would be on individual fuses for safety.. they are, of course, and guess what? The drivers side 15A fuse had popped..
Replaced, tested and it appears OK so I'll hold off replacing things until it blows again (which, I guess, would indicate an electrical fault somewhere to fix.. probably the ballast)!
Post by: 05omegav6 on 10 October 2013, 18:31:15
Ah yes the turn it off and on again approach ;D
Fault could also be the bulb failing :y
Post by: aaronjb on 11 October 2013, 09:12:10
We'll see how long it lasts.. fortunatley the car doesn't see much use - although it'll do a run up to deepest darkest nowhere (Market Deeping) at the weekend to see my folks new place.. I'd take the M3 but we all know what I did do that last weekend ;D
Post by: Jan Suhr on 11 October 2013, 19:15:45
I bought the cheap ones once and I will never do it again, they broke after just one year. Go with Osram they will live for many years.
Jan
Post by: VXL V6 on 12 October 2013, 13:59:07
Jan
Yes, i'd agree with the above.
