Chat Area => General Car Chat => Topic started by: Webby the Bear on 13 October 2013, 13:28:43
Title: MOT expiry question
Post by: Webby the Bear on 13 October 2013, 13:28:43
Hi guys,
Ok well today was full of potential. Was going to work my nuts off to get the car started.
Martin popped round early doors with sealant (cheers mate  :y :y :y), looked outside.... pissing it doon. then get call from the mrs... she's stranded in toon  ::) just got back from rescuing her and tbh i'm cold tired and wet  :'( (i'm a pussy I know).
SO. Omega will be done Wednesday when i'm next free. my question is though..... the MOT expires tomorrow. car will still be insured and still be taxed. can I leave it on the road or do I have to SORN it for the sake of a few days???
cheers  :y
Title: Re: MOT expiry question
Post by: 05omegav6 on 13 October 2013, 13:32:31
Technically it needs to be kept off road :-\ pre booked Mot is a must though :y
Basically man up, get outside and fix it ;D
Post by: Webby the Bear on 13 October 2013, 13:40:57
but its cold  :'( :'( :'( ::) ;D
ok thanks taxi.
Post by: dbdb on 14 October 2013, 01:19:40
Technically you can be fined for driving it without an MOT unless you have a pre booked MOT appointment and are driving it there, as Al mentioned.  No points though and it is quite a small fine - £60. I got fined that taking my last mig to the scrap yard :'( :'(. I'm pretty sure you won't be fined if it is just left on a road, insured and taxed.
Post by: dbug on 14 October 2013, 01:30:47
Pumbien v Vines
(1995) The Times June 14 Queen's Bench Divisional Court
A motor car parked on a road was being used on the road for the purposes of sections 47 and 143 of the Road Traffic Act 1988 even if it was totally immobilised and could only be moved by being dragged away, and, therefore, required both a valid MOT certificate and an insurance policy.
The Court so held in dismissing an appeal by way of case stated by Andee Pumbien against his conviction of offences of using a motor vehicle on a road without either a valid test certificate or insurance policy contrary to sections 47(1) and 143(1) of the 1988 act.
Also potential insurance issues with no MOT ;)
Post by: dbug on 14 October 2013, 01:51:30
Maximum penalty for no MOT is up to £1000 fine, no points
No MOT may well void your insurance cover - larger max fine (up to £2500 max), potential disqualification, and car impounded, plus 3 points.
Post by: AndyRoid on 14 October 2013, 07:17:10
Having no MOT cannot invalidate any insurance policy in force, if it did then we wouldn't be able to drive to & from pre-booked MOT's or any other pre-booked repairs.
All the MOT proves is that the "testable" items were functioning correctly at the time they were tested, it is not a guarantee that the vehicle is roadworthy in any way, shape or form. In fact, it is quite possible for a vehicle to pass an MOT and still be illegal to use on the road.
Post by: Sir Tigger KC on 14 October 2013, 10:15:48
Totally illegal Webby!!!  :o  Get on with it and don't expect any sympathy here IF you get caught!!  ::)  ;D
Post by: Webby the Bear on 14 October 2013, 11:08:28
Gonna SORN it lads. i know i'd get in trouble if i didnt  ::)
Post by: martin42 on 14 October 2013, 11:53:42
Just get it on the drive,no need to sorn it as still taxed.
Post by: Sir Tigger KC on 14 October 2013, 12:55:50
I assumed that you didn't have anywhere 'off road' so as TMM says get it on the drive!  :y  You can't keep a SORNED vehicle on the road either!  ::)
Post by: Webby the Bear on 14 October 2013, 12:56:10
oh ok, thanks martin didnt know that. ill be working on it tonight. wish me luck  ;D
Post by: martin42 on 14 October 2013, 13:05:19
Il pop over after work if you want me to give you a hand
Post by: Webby the Bear on 14 October 2013, 14:05:56
Tonight? You sure mate?
Post by: Webby the Bear on 14 October 2013, 14:06:41
ps, just got a new phone as mines nackered. i got the same numbewr but it didnt save anyones. can you boys (NOOF) pm your phone numbers so i can save them? :)
Post by: TheBoy on 14 October 2013, 17:30:29
As said, no MOT, you have to get it off the road.
Post by: TheBoy on 14 October 2013, 17:31:10
Even if SORN'd (thats what the OR bit stands for ;))
Post by: Webby the Bear on 14 October 2013, 17:59:34
Thanks TB  :y :y :y
Gonna do some work tonight..... using the torch  ::)
Post by: zirk on 14 October 2013, 18:47:07
Just to add, as said pre booked MOT is a must, make sure when you book it in they have all your details, Pre booked means it has to be driven directly there and local, also technically you only have 1 hour before and after the Test (if it fails or you dont have Tax) for it to be legally driven on the road.  :y,
Post by: omega3000 on 14 October 2013, 19:14:45
Thanks TB  :y :y :y
 :o
Brings back memories when the work was being done on mine ...Torch/Umbrella and mucho swearing fitting the cambelt  ::) :(
Post by: Webby the Bear on 14 October 2013, 19:28:46
Thanks TB  :y :y :y
 :o
Well got some stuff done. not much but every little helps. still got a problem with the aux belt tensioner. I fought with it tonight and its still catching the cambelt cover. not sure what to do about it  :-\
Post by: martin42 on 14 October 2013, 20:01:26
Have a look in day light,and call it a day for now,come back to it when your not stressing over it and you will find its something simple to sort out :y
Post by: omega3000 on 14 October 2013, 20:17:12
Oh what joy it would be to have a garage  :( Hopefully next year a heated one .
Post by: Andy B on 14 October 2013, 20:17:36
I can't see that ..... what if you dropped it off on your way to work & then wanted to collect it on your way home 8/10/12 hours later  ::) ::)
Post by: Andy B on 14 October 2013, 20:18:12
You'll just fill it with crap ....... like me!  ??? ;D ;D
Post by: omega3000 on 14 October 2013, 20:28:43
Well the shed will be demolished so you got a point  :-\ Forgot to tell me dad he's laying the bricks  ::)
Got to be ready for the gearbox/clutch party in march/april  :)
Post by: TheBoy on 14 October 2013, 20:31:43
I thought not having a garage would just be a minor inconvenience. Its not, its a constant headache  :'(
Post by: Andy B on 14 October 2013, 20:33:29
It would have been if you'd been outside when it blew up!!  ???  ;)  ;)  ;)
Post by: martin42 on 14 October 2013, 20:34:58
Hopefully have airtools and compressor aswell ready for it.
Post by: omega3000 on 14 October 2013, 20:42:31
Meant to say there are some compressors going on the bay , dont forget the plasma cutta and mig welder  ;)
Post by: martin42 on 14 October 2013, 20:49:54
Not sure why we need plasma cutter and welder unless your doing more then a clutch change on the vectra  ;D
Post by: omega3000 on 14 October 2013, 20:57:49
Its easier to cut the floorpan out of an aging classic , no not the vectra  :P
Post by: 05omegav6 on 14 October 2013, 21:13:07
Could simply be that the cam cover isn't seated properly :-\
Post by: omega3000 on 15 October 2013, 13:45:09
Check 3 times and start only once  ;) Never work in the dark with an umbrella and torch  :-X
