Chat Area => General Discussion Area => Topic started by: r1 on 04 November 2013, 20:33:04
Title: help wanted nipple removal
Post by: r1 on 04 November 2013, 20:33:04
now I have your attention
hows the best way to remove a nipple from a brake cable for a push bike?,as my son new brake cable has a nipple on each end and I have to remove one without destroying the cable so I can thread it.
Title: Re: help wanted nipple removal
Post by: Vamps on 04 November 2013, 20:35:32
A blow lamp, should be soldered........ :y or cut it off but be careful with all the end bits of wire..... ::)
Post by: Andy H on 04 November 2013, 20:36:12
Ask Jimbob!  ::)
Alternatively use good quality sharp side cutters.
Post by: r1 on 04 November 2013, 20:43:56
yeah its the ends of the wire fraying that iam bothered about
Post by: ronnyd on 04 November 2013, 20:45:03
Cut it as close to the unrequired nipple as you can, there should be enough solder left in that part of the cable
to stop it fraying :y
Post by: ronnyd on 04 November 2013, 20:53:36
Ps you can also get crimp on ferrules to put on the cut end of the cable from your local cycle store
Post by: F1 9LFG on 04 November 2013, 21:14:36
What he said  :y
Post by: bigegg on 04 November 2013, 21:21:23
I use a pair of end nip cutters which are double hinged, like a bolt cropper.
These cut the ends so perfectly that the remain twisted together.
You *can* weld the ends of the cable back together (well, I can  :y ), but easier just to solder - even then, they sometimes untwist with the heat  :(
*Sharp* cold chisel, and a good hard smack to cut through all the wires together is another, workable, way
Post by: bigegg on 04 November 2013, 21:22:09
What he said  :y
but they won't fit through the cable outer  :(
Post by: F1 9LFG on 04 November 2013, 21:30:37
What he said  :y
Ah, sorry - missed the bit about wanting to thread it after cutting.  :-[ in that case, as you say  :y
Post by: ronnyd on 05 November 2013, 13:08:29
Best not to fit the ferrule on until you have got everything else sorted.  :y
