Chat Area => General Discussion Area => Topic started by: Terbs on 05 November 2013, 09:27:11
Title: A very close call...
Post by: Terbs on 05 November 2013, 09:27:11
These people were very lucky......gross error by a pilot by the looks of it :o
http://usnews.nbcnews.com/_news/2013/11/04/21308806-exclusive-images-show-skydivers-terrifying-collision-and-chaotic-plunge?lite
Title: Re: A very close call...
Post by: Varche on 05 November 2013, 10:24:20
Gosh.
Post by: cleggy on 05 November 2013, 11:41:43
OOPS ! :o
Post by: Kevin Wood on 05 November 2013, 13:08:45
Both aircraft in each others' blind spot and one climbing / the other descending.  :(
Given that they presumably were known to each other and in radio contact they should have been able to avoid that. Looks like they were lucky to walk away.
Not sure the pilot who landed was wise to do so, TBH. If I were flying that aircraft and had a parachute (he may not have, of course) I'd have left it to its' own devices rather than risk it coming apart lower down. Exactly that decision killed a member of our gliding club a good few years back. :(
Post by: aaronjb on 05 November 2013, 13:27:59
Gosh.
I bet that wasn't the first word out of their mouths..
Post by: Field Marshal Dr. Opti on 05 November 2013, 13:36:50
Gosh.
Unless 'Gosh' starts with an 'F'. ::) ::) ;)
Post by: Webby the Bear on 05 November 2013, 13:44:33
Jesus Christ!!!! I knew there was a reason I was scared of heights  ::)
Post by: omega3000 on 05 November 2013, 15:55:54
Could have been a lot worse . How could you make such a mistake  :(
Post by: Kevin Wood on 05 November 2013, 16:54:31
Given that it appears to have been a coordinated jump I wonder why they didn't form up in such a way that the aircraft could see each other throughout. It seems one was following the other, and the sun was low in the sky. I wonder if the following aircraft lost sight of the leading aircraft and overtook it, then climbed or descended into it?
Quite apart from the risk to the aircraft, dropping parachutists with one aircraft following another seems to me to be a recipe for someone to get mashed up in a propeller. :o
Post by: Entwood on 05 November 2013, 17:10:33
exactly ... in all the drops I've done, and its in the hundreds - note.... flying the aircraft NOT jumping out of a fully serviceable one !! - there are only FOUR possible aircraft positions for a multi drop.... and the aircraft should ALWAYS have matched speeds
1. Aircraft at same height, wingtip to wingtip
2. Aircraft at same height, line astern, very close so as to almost be one aircraft and all jumpers leave both aircraft at the same time.
3. Aircraft at the same height, line astern, distance between depends on speed but all jumpers depart when over the same point on the ground - this ensures the jumpers from the first aircraft are well clear by the time the second aircraft reaches the ground release point - this is the most common military method, for what is called a "stream assault"
4. Aircraft at different heights, following aircraft is ALWAYS higher than lead aircraft, this ensures that as the jumpers leave the second aircraft the lead aircraft is travelling away from them faster than their forward throw, and the gap is getting bigger.
It is possible to do multi drops from aircraft of very different speeds - C130 with Dakota being one we did lots of... especially at this time of year ... but the planning and co-ordination was very meticulous to avoid any danger to the jumpers
Post by: 05omegav6 on 05 November 2013, 18:07:31
It would take more than a bump from a C130 to knock a Dakota out of the sky ::)
Post by: Entwood on 05 November 2013, 19:26:29
True, but the 4 Alison t56-15 turbos with 15 foot Hamilton Standard propellors on the front would make a pretty severe mess of any jumper that got too close .. and that was always the worry, its easy to avoid another aircraft - providing you keep a decent lookout - far harder to spot and avoid a parachutist !!
Post by: 05omegav6 on 05 November 2013, 19:58:50
Especially at night :-\
