		Omega Help Area => Omega General Help => Topic started by: Toledodude1973 on 08 November 2013, 16:58:31
				Finally got around to fitting new SL shocks which all went great following the guide,the old shocks were both quite rusty with one leaking. However as most Mig owners know 1 fault sorted normally means another is not far away. The central locking on the drivers door sometimes works but mostly fails or just moves a little, does this mean motor is dead or is it failing from somewhere central? Any help appreciated thanks
				Drivers door solenoid failing :'(
				Is it fairly easy job and can anyone confirm part number please
 http://www.omegaowners.com/forum/index.php?topic=90504.0  (http://www.omegaowners.com/forum/index.php?topic=90504.0) :y
Over to our man in Bristol for pic/part number...
				Thanks Al ,Having a 2002 model part no.90493702 from the guide would stll be correct yes? any idea of cost now , was 30/40 back in 2006 ,any tips on fitting would be great thanks
				I might have one in my shed.Will have a look tomorrow. :y
				Thanks Albs , seems to be behaving itself again but will let you know if it fails again  :( So please don't look too hard just yet mate, cheers paul
				Oops forgot to say is that the right part number for a drivers side 2002 motor?
Yep
				Thanks Rob i knew the numbers guru would come up trumps  :y
				Found two but the part number on both is 90493703 - I presume they are rears then ?
				Thanks Albs back to Rob for numbers of rears :)thankyou
Yep
				thanks for numbers Rob , i'll go down the GM route any idea of cost anyone?front central locking motor
				http://www.vauxhall-car-parts.co.uk/cgi-bin/ss001234.pl?page=search&SS=90493702&PR=-1&TB=O&ACTION=Go%21
