		Omega Help Area => Omega General Help => Topic started by: darrenfos on 18 November 2013, 21:23:26
				anyone know what can be done to revive the rubber on the door card grab handle, and around the window switch. They seem to scratch real easy (there a horrible design)
				Search and you shall find ::)
 (hint... October last year in 'What have you done to your car...')
 Show off  :D
 Mind you,  you did a great job  :y
				i had a look yesterday, quick question how do you get the rubber off is there any solvents you could advise because i dont want to scratch the plastic.
				Thanks :-[ :y
 Holding up well considering the crap it puts up with 8)
 Solvents will dissolve the plastic as well ::) lots of wet and dry. Start coarse 200 grit, and work your way to 2000 grit, then either paint or polish :y
 Easier if all stripped off the door card first :y
				bang on, i always strip the part first not, like the Muppet's that just go for it and get the spray everywhere, cheers.
				Thanks :-[ :y
 I can only imagine  :-X
 It's still on my wish list of jobs but haven't managed it yet  :-[
 Part of the problem is colour, though another member used plastidip stuff with good results on a cream interior.
				Thanks :-[ :y
 That's the beauty of the Tamiya paint I used... hundreds of colours with different finishes...matt/satin/gloss being the obvious three and covers far more predictably than so called specialist products :y
				Thanks :-[ :y
 Thanks al. Here I go again .........  ;D
 Had considered doing the wood effect bits too, but which colour? Beats me  :-\
 I guess could be the same as the pockets,  but would the dash area look odd then?
 Decisions, decisions  :D
				I might veneer the 'wood' next time :-\ might be easier said than done though...
				MarkC (where is he right enough??) used a vinyl on his iirc, but there's just too many colours going on in mine   :-\
				The cream interior can easily be toned down with black/charcoal carpets, lower trims and door cards, keeping the cream lower dash, seats and leather/vinyl door panels :y
 Unless of course yours is an early facelift with the poo brown dash/wheel/centre console ::)
				No offence to any current owners, but that brown dash was shocking! Imo of course  ;)
				just striped the door down regarding the grommets i wag going to replace with screws that fit in the hole's like the self tapping ones, any ideas?
				(http://i971.photobucket.com/albums/ae199/darrenfos/20131119_182822_zps551d996e.jpg) (http://s971.photobucket.com/user/darrenfos/media/20131119_182822_zps551d996e.jpg.html)(http://i971.photobucket.com/albums/ae199/darrenfos/20131119_182740_zpse812b770.jpg) (http://s971.photobucket.com/user/darrenfos/media/20131119_182740_zpse812b770.jpg.html)
 might try and get a blue-grey spray, not sure yet looks better than the pic's. not bad first attempt. :)
				Looks good mate - keep it up  :y
				(http://i971.photobucket.com/albums/ae199/darrenfos/20131124_142358_zps53b79447.jpg) (http://s971.photobucket.com/user/darrenfos/media/20131124_142358_zps53b79447.jpg.html) rear door looking allot better
				Looking good :y
				Looking good :y
 Absolutely  :y
				cheers was worth it
				What products did you use in the end?
				rubbed down with wet and dry under running warm water, then i used a halford's satin black, then lacquer on top to seal it then baked over night above the boiler
				Nice one, thanks. I don't like the thought of taking it apart in the first place  :-X
				no i didn't but its not to bad, if fact it's quite easy.
