Chat Area => General Discussion Area => Topic started by: Mr.OmegaMan on 02 December 2013, 20:12:08
Well i got my replacement iPhone 5 back from apple today a new device, Before sending the old one back i had made a backup copy to iCloud and iTunes on the laptop.
I'm trying to restore the iPhone using iTunes on the Laptop, Which i did and everything was back apart from the apps, I tried to sync the apps from the Laptop and it went through the loading bar steps, 1,2,3, 4 etc and it just says Sync Cancelling.
So i'm trying to restore the phone again, But i'm sure that wont fix this hiccup i'm having... I would try iCloud but my internet is too slow for that, But if it came to the worst i could use iCloud i suppose.
Any ideas ???
Any ideas ???
Get an android. :y
Any ideas ???
Get an android. :y
Useful info as usual. ::) :P
I'd be tempted to start as new device tbh. Transfer the contacts, but otherwise leave the pc alone.
...is it worth re installing iDooms?
Just finished another restore.. No apps restored again.
How long should i wait for this to finish, I don't see any Sync wheel turning on the iPhone or any Apps popping up..
(http://s9.postimg.org/ytwmr4vkv/hth.png)
iTunes/iDooms ?
But if i did that wouldn't i lost the Backups and Apps on the Laptop ?
iTunes/iDooms ?
I have a cold. :(
Check, ffs don't take my word for it, but no, I didn't. Others will advise I'm sure.
Get an android. :y
:y :y :y
Comparing crApple and Androik at work, Anroik is no good for me.
Although I forget why. :(
Give me strength........sigh...
What now? Smelling, or forgetting? ;D
Go to app store on phone,and then select purchased, :y
Going down this road, iTunes has tested my patience enough. :)
Sorry if i seem grumpy, Well i am kinda, Havin'g to sort through 240 apps now then, Dont need half of them really ;D
Apps don't restore, if you had the phone save all apps to the PC/mac you can drag n drop to the phone otherwise it's App Store, purchased, then re install each desired app.
Yep it wouldn't do that mind for some reason kept cancelling.
90% done now id say doing it (manually) from the app store.
iTunes? Good luck with that. Handy for wiping iDevices accidentally though...
And for porking pc's.
How do you do this with android ? Back up to computer to an Android type of iTunes ?
Android handsets are simply seen as external disk drives, you drag & drop whatever you want once it's connected to the PC.
Ah okay, So you back it up to the PC in a folder or something..
Yup. No different to gayTunes, only you have more some control over what it does.
This replacement iPhone 5 i got end of November 2013 has now turned faulty, Apparently a Logic Board Failure or something >:(
So yet again sending back to Apple for my 4th yes 4th Replacement iPhone 5 32GB Black. Really don't think i can trust the iPhone 5 any more.
1st: Dead Pixel (Day of arrival was like this)
2nd: Faulty Battery (Lasted 12 months)
3rd: Logic Board Failure (Lasted just over a month)
4th: ........................
Really need to find something to replace it with when i get the replacement i intend to sell it.
5's do appear to suffer from build issues, had a few failures in the office, top lock button being a common failure.
i'll stick to my iphone4 then.....unless anybody leaves a 5 in the back of my cab ::) ;D
Guess you're ready to crossover to the dark side (Android) then.
How have the 5S model's been behaving overall ?
I do have a Asus MeMo HD 7 16GB android tablet, When the iPhone was working it felt more like home sort of thing using iOS seems less complicated and more smooth.
Originally I was planning on keeping the 5 till the next gen iPhone came out rather than the 5S, Just don't know if this next replacement will last till then :-\
