		Omega Help Area => Omega General Help => Topic started by: PhilRich on 05 December 2013, 20:23:50
				Does anyone know what differences there are between the Y22XE and Z22XE omega engines please? ???
				y22xe-less power and is omega other is frontera and older?
				Thanks for the quick reply symes :y
 Actually both those engines are fitted to the 4 pot 2.2 omega, but I need to know if they share the same cyl. head, cams, valves etc :-\
				One is chain driven, the other belt.
				not sure about cams--as one engine is for 4x4---so could be different--is it a case of head gone or something?
 nope-both belt----x22dt is chain ;)
				also x/y on engine code is to do with compression of engine iirc
				The only noticeable difference between them are the ECU and the inlet diameter is a whopping, or even humungous 1mm bigger ::) ;D
 Oops my bad :)
 Hi Rob, thanks for that :y
 So could I fit a Y22XE cyl. head onto a Z22XE block and reconnect existing electrics/electronics without any fuss :-\ ;)
				Yep, physically the blocks and heads are the same
				You're a National Treasure Rob! Thanks again matey! :y
 and thanks too to symes and Dan282 :y
 Emissions control. X = euro 3 emissions standard.   Y = euro 4 standard
