Omega Help Area => Omega General Help => Topic started by: Ralph on 10 December 2013, 23:35:28
Title: Glove Box
Post by: Ralph on 10 December 2013, 23:35:28
I can't get my glove box open !
The lever/ handle has pulled out & stayed out, there feels to be a cylindrical part that's come out with it.
I can't get the lever / handle to go back.
Any ideas how I can get it open or what's gone wrong ?
It's dark at the moment so I'll have another look in daylight, it seems to be just one thing after the other at the minute  :'(
Title: Re: Glove Box
Post by: jonny2112 on 11 December 2013, 00:58:13
There's a guide in the maintenance section about this issue, although I'm not sure if it suggests how to open the glove box on the first place  ???
It is a common enough problem so someone should have an idea  :y
Post by: 05omegav6 on 11 December 2013, 01:12:45
Handle should clip back in... kind of... can then be used sort of normally :y
You do need the glovebox open to remove it though :y
Post by: Shallow Al on 11 December 2013, 02:36:25
Mine went as well recently. I can, (ahem), put my finger in the hole left by the broken handle, and push downwards, and mine comes open.
Its going to stay that way for a while until the weather warms up. :-[
hth :y
Post by: PhilRich on 11 December 2013, 07:44:38
Try pushing the glovebox box door backwards & upwards at the same time quite firmly to take the strain off the latch and then jiggle the lock handle back into place  :y
Post by: flyer 0712 on 11 December 2013, 16:19:01
Finger through aperture and push down..as stated..easy peasy. :y
Post by: Ralph on 12 December 2013, 08:05:32
Thanks all, I've got in to it  pins are  :ybroken on catch, new one required now. :y
Post by: PhilRich on 12 December 2013, 20:29:39
Have a look here :y
http://www.omegaowners.com/forum/index.php?topic=90660.0
Post by: albitz on 12 December 2013, 20:31:50
Got a complete glovebox here,but it would cost a few quid to post.
Post by: mrgreen on 13 December 2013, 07:12:51
bit of a pita to replace, cheap fix though
