Omega Help Area => Omega General Help => Topic started by: plym ian on 14 December 2013, 10:03:04
Pretty sure I found a guide to this on here but can't seem to find it now.
Basicly blowing hot passenger side and cold drivers any help please.
Cheers Ian
http://www.omegaowners.com/forum/index.php?topic=119326.0 :y
Cheers Ian
Whereabouts are you Ian? Having just suffered the same issue, I'd be more than happy to help you out if your close by mate :y
Cheers Ian
Plymouth Devon
Cheers Ian
Plymouth Devon
Local then! ;D ;D ;D
Cheers Ian
Did you resolve yours?
Cheers Ian
I did mate. Being totally stupid, didn't realise that there were motors in both footwells. I checked the passenger footwell as per the guide and that was fine, didn't realise that there would of been one the other side. I assumed that the motor did both sides since there was no mention of drivers side, lol. Live and learn!
I fixed mine by screwing a small screw into the motors plastic arm, so that the arm coming down from above had a bigger "pin" to hold onto.
Only thing now is the heaters are still not that hot. Will do another matrix flush now I've resolved that initial problem!
Dave let's go on another road trip ? ;D :y
How's there's a thought :y
Cheers Ian
Was this for the blend flap? Got any pictures?
Suspect I have same problem with my 3.2, centre vents red hot on high. Side vents and rear are cool.
Cheers Ian
Unfortunately I didn't take any pictures mate, sorry :-[
It does sound like you have the same problem, but both sides. All I did was unplug the motor undue the screws holding the motor in place and withdrew it. Used a self tapping screw and screwed it onto the raised nipple on the arm on the back of the motor. Make sure though that the arm coming down from above, the hole will go over the head of the screw!!
Works a treat now, although it's still not very hot heat coming through on any vents. It's warm, but not hot. HTH's :y
Thanks for that, can't visualise what you mean. Will need to get my head down there and take a look :y
Both sides cold? Thats different to what you told me. You said just passenger side was cold?
Trying to remember now :-[
Been a few weeks since I drove 3.2, only the centre dash vents got as hot as they should. Ie almost burn your hand
Had a look at mine today and it was the arm came off the motor bit. Managed to clip arm back on and now I have heat on drivers side. Cheers guys oof saves the day(and a costly trip to dealers!)
A nice easy fix once you get to grips with it :y
Helps refitting if you set the temp to Lo as that's the default setting for the flap when the arm detaches :y
Saves trying to fight it when refitting...
Nice one buddy. This forum has been a god send to me too. Great feeling when you learn something new, fix it and save a fortune as well :y
