Chat Area => General Discussion Area => Topic started by: JamesV6CDX on 02 June 2008, 01:38:03
Title: A productive morning on project no fear!
Post by: JamesV6CDX on 02 June 2008, 01:38:03
I did a few jobbies this morning on the project 2.0 no fear Estate:
1) Sorted out camcover gasket, sealed with correct black sealant. Drained plug wells and cleaned everything out, incl HT leads.
2) Finally got the EML to go out. Changed the lambda sensor. Had a right bargain, got a titania one from a 2.0 Omega from the scrap yard while passing - £1 :D
3) Sorted out the fast idle. There were 2 issues, one was a stripped thread on the ICV to throttle body join, so it was letting in air. The other was someone had wedged the TBody open a bit probably to cure an idle/stalling problem. So - I re-threaded the damaged hole and re-fitted the ICV, and sorted out the Tbody, and she now idles perfectly.
4) ATF - I did the ATF today, made a nice mess but the gearchange feels good now¬
5) Tunage - I fitted a Sony Head Unit (Sorry Jaime) - because I lost the code to the CDC... sounds lovely but I need to sort out the memory wire!
6) I did plan on a few other jobs such as clean up the headlights, steam clean the interior etc.. but it started raining, so I thought I'd take it for a spin back to Maria's instead :y :y
Title: Re: A productive morning on project no fear!
Post by: STMO123 on 02 June 2008, 08:07:53
A sign of someone who knows what they are doing James is not just being able to put things right, but being able to diagnose the problem in the first place.
You certainly have picked up a lot in a relatively short time. Well done :y
Post by: Dazzler on 02 June 2008, 09:05:15
Normally you just swap the yellow and red wire around as Vx have these two the opposite to everyone else ::)
Post by: HolyCount on 02 June 2008, 09:10:53
Good to hear it's all coming together nicely  :)
Post by: Martin_1962 on 02 June 2008, 11:22:45
Or a cheap adaptor off Ebay
Post by: TheBoy on 02 June 2008, 19:10:34
Stuff ya sony up ya jacksie  >:(
I think Tunnie is hoping you're in a productive mood for putting a head back on a 2l soon ;D
Post by: JamesV6CDX on 02 June 2008, 19:46:38
Is it off? What's the score, what have I missed?? What are the internals like, and why wouldn't it start?
Post by: TheBoy on 02 June 2008, 21:16:14
This is Tunnie, or course its not off ;D
No 2 has bugger all compression though. No 1 in the green, but lower than 3 and 4.
