Omega Help Area => Omega General Help => Topic started by: omega3000 on 19 December 2013, 20:34:35
Does it have a seal/gasket/o'ring ??? Or do you just use a blob of sealant :)
(http://images.omegaowners.com/images/guides/v6_cranksensor_replacement/IMG_0274.jpg)
O ring.
O ring.
I am to inspect it at some point , i think it mite have been weeping for some time ... just wanted to get the parts there ready if it is ;)
New o-ring comes fitted to new sensor ;)
Crank sensor is working ok mate , just suspect its leaking so o ring could be knackered :-\ Not had a chance to look yet but drip drip on the drive is from that area . Either that or the oil filter not sealing ::)
I have an o ring set so will see if i got one to fit , guess the o ring doesn't have to be genuine
Does have to be nitrile, or equivalent, as oil not good with a "standard" o-ring ;)
You know what to do ;D
Nitrile, viton, mbr anything will do it. Even genuine don't last for ever. As you've discovered, they harden up.
I've just done a job on A corsa b with a fuel leak,the injector o ring where it fits into the rail had gone all icky and was passing fuel.
;D :-X :-X
