Omega Help Area => Omega Electrical and Audio Help => Topic started by: Bionic on 27 December 2013, 05:31:23
??? My CCR2006 started to 'hiccup' on tracks and so I took out the magazine to clean the disks and then load a CD Cleaner disk to clean the optics. I cleaned all of the disks that came out and opted to change them for the new ones I had for Xmas. I loaded 3 new ones straight out of their cases (all 3 recent releases on top labels) and then a new CD optic cleaning disk in the 4th slot and put the magazine back in. Now it does not retain the CD Magazine and ejects it immediately telling me that there is 'no magazine'!
The unit has never been abused or given any problems prior to this episode. Any ideas on what is wrong and if I can somehow repair it? I have tried both of my magazines with all new disks with no luck. Then I gave it a good :-X :-X :-X :-X but still no luck.... ::)
I have also advertised for a unit in the Wanted section in case there is no solution.
Boring with only the radio and the tape is way too slow.............. >:(
I use an adaptor in the tape slot for my iphone music. Not sure if the cdc issue is mechanical or electrical. If you have the code, is it worth removing/reset?
Someone will know, but the unit seems prone to issues. Ultimately you only need a compatible cdc3, which can come from any 2006 unit, but prices seem to be very high atm. Must be demand due to aforementioned issues.
Should have added that if you replace the cdc alone, there is no need to recode, etc as the code only applies to the main part of the unit.
Hm, I do have another unit but without the code so I reckon I will give it ago and so if it resolves the problem.
Thanx for the info.... :y
::) ??? Any idea of how I take apart/seperate the cd unit from the radio part?
Have a read of the maintenance guide
4 Disc CD Autochanger repair (Facelift Headunits) (http://www.omegaowners.com/forum/index.php?topic=90608.0)
;D Cheers, Had a looky at that and I have now got the two parts seperated off the spare unit I don't have a code for. Just waiting now for a bit of fine weather so I can get outside and get it swapped over.
Must find those removal tools first though, or revert to fence wire like I had to last time............
Happy days........
When I got my car the cd part was missing so I replaced it. If I can do it .....?
Biggest problem is getting the HU out of the dash!
:y ;D
Spent under an hour this morning and got the job done. Bit fiddly but there again its a miggy and they are bstads to work on anyway so it was not unexpected.
Biggest problem I faced was the sheer number of different driver bits needed! Why oh why cannot the design pillocks (diplomas and no common sense) see that it would be more cost effective to have as many as possible of the parts the same type and size? Stiil, I suppose they have to justify their worth somehow (polishing a seat is not a long job) and make it as difficult as possible for the maintenance guys!
Anyway the job is sorted and many, many thanx for the help.
Now we'll have music wherever we go.............
Nice one. Well done. Always a great feeling when you can resolve it yourself :y
